- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: S3 <scubed2 AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prove inductive type implies false in cycle
- Date: Tue, 2 Aug 2011 12:41:41 +0200
> I will try to make an exemple for that.
Ok, it is not a good one, and I probably could have make it shorter,
but it illustrates what I meant in my previous mail.
Require Import List.
Section X.
Variable A: Type.
Fixpoint last l (a: A) :=
match l with
| nil => a
| a::l => last l a
end.
Inductive constant: A -> list A -> Prop :=
| Cnil: forall a, constant a nil
| Ccons: forall a l, constant a l -> constant a (a::l).
Lemma Y: forall b a, a = b -> forall l, constant a l -> last l b = a.
Proof.
intros b a Heq l H.
induction H; simpl; auto.
(*ok, the proof is easy, and quite artificial,
but with the other definition of constant,
it will be easier *)
now subst; auto.
Qed.
Inductive constant2 (a: A): list A -> Prop :=
| Cnil2: constant2 a nil
| Ccons2: forall l, constant2 a l -> constant2 a (a::l).
Lemma Z: forall b a, a = b -> forall l, constant2 a l -> last l b = a.
Proof.
intros b a Heq l H.
but as we can see, Heq didn't have to be generalized *)
now subst.
Qed.
End X.
- [Coq-Club] Prove inductive type implies false in cycle, S3
S3
- Re: [Coq-Club] Prove inductive type implies false in cycle, Brian Huffman
- Message not available
- Re: [Coq-Club] Prove inductive type implies false in cycle, Pierre Casteran
AUGER Cedric
- Re: [Coq-Club] Prove inductive type implies false in cycle, AUGER Cedric
- Re: [Coq-Club] Prove inductive type implies false in cycle, Michael Shulman
S3
