- To: coq-club AT inria.fr
- Cc: Marco Servetto <marco.servetto AT gmail.com>
- Subject: Re: [Coq-Club] Finite Maps
- Date: Fri, 05 Aug 2011 08:04:34 -0400
I think [Axiom] and [Parameter] are synonyms in all contexts.
Marco, I will extend Cedric's advice by suggesting that you read the documentation not just on sections, but also on the module system.
AUGER Cedric wrote:
Le Fri, 5 Aug 2011 12:30:51 +0200,
Marco
Servetto<marco.servetto AT gmail.com>
a écrit :
This library looks promising.See the chapter about "Sections" for more informations.
There is any documentation/guide/simple example of use of it?
(i'm not interested in exporting programs, i need it only to make
proofs)
what is the meaning of
Axiom eq_refl : forall m : t, eq m m.
Axiom eq_sym : forall m1 m2 : t, eq m1 m2 -> eq m2 m1.
It looks like it assert that some function have some properties
instead of requiring the user to provide such proofs.
It is right?
And... err, my coq ignorance... what is the meaning of
"Parameter" it looks like it autodeclare a parameter with such
name/type in all the following function, but:
-what is the scope of such declaration?
-what is the difference with "Hypothesis"?
Basically, the scope is between the declaration and the "End" of the
deepest section at declaration time.
A little like "Lemma" "Corollary" "Theorem" and
"Definition",
Parameter(s) is basically the same as Hypothesis (and
Variable(s));
I don't know if Axiom works the same way, I should take a look at the
reference manual for more enlightment.
- [Coq-Club] Finite Maps, Marco Servetto
- Re: [Coq-Club] Finite Maps,
Xavier Leroy
Marco Servetto
AUGER Cedric
- Re: [Coq-Club] Finite Maps, Adam Chlipala
AUGER Cedric
Marco Servetto
- Re: [Coq-Club] Finite Maps, Marco Servetto
Marco Servetto
AUGER Cedric
AUGER Cedric
Marco Servetto
Xavier Leroy
