- To: Marco Servetto <marco.servetto AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Finite Maps
- Date: Sat, 06 Aug 2011 08:46:04 -0400
Marco Servetto wrote:
Yep, I have readed.
Have you read Section 2.5 of the Coq manual, called "Module system"? IfNo, I dont
that is not a sufficient introduction,
have you read Chapter 2 of the OCamlWait... you are saing that in order to learn coq i must learn OCaml before??
manual, "The module system"?
http://caml.inria.fr/pub/docs/manual-ocaml/manual004.html
OCaml's module system is the inspiration for Coq's. Coq documentation is
prone to avoid giving details on features that are inherited.
I don't know, but this is the best path I know of to get up to speed with using the Coq map and set libraries, much better than getting the direct answers to your questions.
That part of the OCaml manual is quite short.
- [Coq-Club] Finite Maps, Marco Servetto
- Re: [Coq-Club] Finite Maps,
Xavier Leroy
Marco Servetto
AUGER Cedric
Adam Chlipala
AUGER Cedric
Marco Servetto
- Re: [Coq-Club] Finite Maps, Adam Chlipala
- Re: [Coq-Club] Finite Maps, Marco Servetto
Marco Servetto
AUGER Cedric
Adam Chlipala
AUGER Cedric
Marco Servetto
Xavier Leroy
