- From: frank maltman <frank.maltman AT googlemail.com>
- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] Unexpected axiom in extraction
- Date: Sat, 6 Aug 2011 13:58:38 +0000
Hello.
There appears to be a bug or some sort of strange behaviour when extracting
modules with signatures and axioms:
--8<--
Module Type TEST.
Parameter foo : nat.
End TEST.
Module Test.
Axiom foo : nat.
Extract Inlined Constant foo => "prim_foo".
End Test.
Axiom bar : nat.
Extract Inlined Constant bar => "prim_bar".
Definition x := Test.foo + bar.
--8<--
$ coqc Test.v
$ coq
< Require Test.
< Extraction Library Test.
The file Test.ml has been created by extraction.
The file Test.mli has been created by extraction.
$ cat Test.ml
open Datatypes
open Peano
module type TEST =
sig
val foo : nat
end
module Test =
struct
end
(** val x : nat **)
let x =
plus prim_foo prim_bar
Now, adding ": TEST" to the module...
--8<--
Module Type TEST.
End TEST.
Module Test : TEST.
Axiom foo : nat.
End Test.
Axiom bar : nat.
--8<--
$ coqc Test.v
$ coq
< Require Test.
Warning: The following axiom must be realized in the extracted code:
Test.foo.
$ cat test.ml
open Datatypes
open Peano
module type TEST =
sig
val foo : nat
end
module Test =
struct
(** val foo : nat **)
let foo =
failwith "AXIOM TO BE REALIZED"
end
(** val x : nat **)
let x =
plus Test.foo prim_bar
Note that, now, Test.foo is an unrealized axiom!
- [Coq-Club] Unexpected axiom in extraction, frank maltman
- Re: [Coq-Club] Unexpected axiom in extraction, Adam Chlipala
