coq-club - Re: [Coq-Club] Unexpected axiom in extraction
chronological Thread
  • To: frank maltman <frank.maltman AT googlemail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Unexpected axiom in extraction
  • Date: Sat, 06 Aug 2011 10:08:31 -0400
frank maltman wrote:
Module Type TEST.
   Parameter foo : nat.
End TEST.
Module Test : TEST.
   Axiom foo : nat.
   Extract Inlined Constant foo =>  "prim_foo".
End Test.
Axiom bar : nat.
Extract Inlined Constant bar =>  "prim_bar".
Definition x := Test.foo + bar.
--8<--
$ coqc Test.v
$ coq
<  Require Test.
<  Extraction Library Test.
Note that, now, Test.foo is an unrealized axiom!
That makes sense to me. It's an unrealized axiom in Coq, too! It seems entirely consistent with opaque signature ascription that the [Extract Inlined] command is hidden to code outside [Test], since it doesn't appear in [TEST].
