- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] A proof I'm having difficulty with
- Date: Wed, 17 Aug 2011 07:08:57 -0700
- Importance: Normal
Thanks everyone. I solved the proof. The one tip below was useful. If anyone is interested in seeing the solution, I can mail it out. Unfortunately, it is difficult to extract from the rest of my framework and I don't feel like posting the entire framework at this time.
- Ken > Date: Tue, 16 Aug 2011 21:23:54 -0400 > From: adamc AT csail.mit.edu > To: kendroe AT hotmail.com > CC: coq-club AT inria.fr > Subject: Re: [Coq-Club] A proof I'm having difficulty with > > Kenneth Roe wrote: > > I have abstracted out the appropriate definitions from my model. I'm > > trying to figure out a good approach for this proof. I'm pretty sure > > that it requires classical logic. The key to the proof is to show > > that "v < vars" in the theorem at the end. To do this, I'd like to > > assume that v >= vars and then construct an m and m' that are counter > > examples to the first hypothesis. How can I set this up? I've > > included all the relevant definitions. Hopefully, some Coq guru can > > solve this quickly. > > I haven't yet read any of the code you included below, but I thought it > worth pointing out that proof by contradiction is valid for all > decidable propositions (or at least those decidable within CIC), even in > constructive logic. If your [v < vars] fact uses the usual natural > number comparison, then you can prove a lemma for the contradiction > rule. The decidable tests like [le_lt_dec] in the Coq standard library > should let you prove this lemma without any induction. |
- [Coq-Club] A proof I'm having difficulty with, Kenneth Roe
- Re: [Coq-Club] A proof I'm having difficulty with,
Adam Chlipala
- RE: [Coq-Club] A proof I'm having difficulty with, Kenneth Roe
Adam Chlipala
