coq-club - Re: [Coq-Club] Problem using a functor
chronological Thread
  • To: Emmanuel Polonowski <polonowski AT u-pec.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Problem using a functor
  • Date: Thu, 01 Sep 2011 09:58:43 -0400
Emmanuel Polonowski wrote:
Thank you for the hint ! It works fine now...
Is there a document providing an introduction or some explanations about this
point or the fundamentals of the module system ?
That information is probably present in Section 2.5 of the Coq manual. For instance, you can see that the non-terminal "module_expression" clearly only allows application to qualified identifiers ("qualid"s).
The point and fundamentals of Coq's module system are pretty much the same as for ML module systems. If you're not familiar with those, you might want to read up on one (e.g., OCaml's).
