- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem using a functor
- Date: Fri, 2 Sep 2011 13:18:09 +0200
Thanks again, I'll have a look at it.
Le 1 sept. 2011 à 15:58, Adam Chlipala a écrit :
> Emmanuel Polonowski wrote:
>> Thank you for the hint ! It works fine now...
>> Is there a document providing an introduction or some explanations about
>> this point or the fundamentals of the module system ?
> That information is probably present in Section 2.5 of the Coq manual. For
> instance, you can see that the non-terminal "module_expression" clearly
> only allows application to qualified identifiers ("qualid"s).
> The point and fundamentals of Coq's module system are pretty much the same
> as for ML module systems. If you're not familiar with those, you might
> want to read up on one (e.g., OCaml's).
Emmanuel Polonowski
Université Paris-Est Créteil - LACL - ESIAG
http://lacl.u-pec.fr/polonowski
- Re: [Coq-Club] Problem using a functor, Adam Chlipala
- Re: [Coq-Club] Problem using a functor, Emmanuel Polonowski
