- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: ldou AT cs.ecnu.edu.cn
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] the context of sequence diagram
- Date: Sun, 18 Sep 2011 09:50:47 +0200
Hi,
There are two precisions that should be made :
I assume a) that the "x" points out to a position where seqDiag is expected
b) there is exactly one occurrence of "x".
With these assumptions, one can define a type called "context" in the
attached file.
But the best is to have a look at Gérard Huet's proposition for writing
contexts : the zipper data structure.
http://en.wikipedia.org/wiki/Zipper_%28data_structure%29
The best,
Pierre
Quoting
ldou AT cs.ecnu.edu.cn:
hi,guys,
i'm using Coq to formalize the Sequence Diagram. The following inductive type of sequence diagram has been defined:
Inductive seqDiag:Set :=
|DE: event ->seqDiag
|DStrict:seqDiag->seqDiag->seqDiag
|DPar: seqDiag->seqDiag->seqDiag
|DSeq: seqDiag -> seqDiag ->seqDiag.
Then i want to define "context" in Coq. According to our concept, a context is a sequence diagram with one of its fragment replaced by a special symbol x, just like term rewriting. how should i define "context"? any suggestions are appreciated.
Best regards!
窦亮
华东师范大学计算机科学技术系
(Department of Computer Science, East China Normal University)
E-mail:ldou AT cs.ecnu.edu.cn
Parameter event : Type.
Inductive seqDiag:Type :=
|DE: event ->seqDiag
(* type of seqDiags with exactly one hole (where a seqDiag is expected) *)
Inductive context : Type :=
Hole |
CStrictL : context -> seqDiag -> context |
CStrictR : seqDiag -> context -> context |
CParL : context -> seqDiag -> context |
CParR : seqDiag -> context -> context |
CSeqL : context -> seqDiag -> context |
CSeqR : seqDiag -> context -> context .
(* replacing the hole with d *)
Fixpoint fill (d:seqDiag) (gamma:context) :seqDiag :=
match gamma with
Hole => d |
CStrictL gamma d' => DStrict (fill d gamma) d' |
CStrictR d' gamma => DStrict d' (fill d gamma) |
CParL gamma d' => DPar (fill d gamma) d' |
CParR d' gamma => DPar d' (fill d gamma) |
CSeqL gamma d' => DSeq (fill d gamma) d' |
CSeqR d' gamma => DSeq d' (fill d gamma)
end.
Require Import List.
Open Scope list_scope.
(* building a context from a seqDiag and a path
1 for left son, 2 for right son *)
(* I should use the monad notations :-) *)
Fixpoint diag2context (d:seqDiag)(p:list nat) : option context :=
match d,p with
| d,nil => Some Hole
| DE e, _ => None
| DStrict d1 d2, (1::p') => match diag2context d1 p' with
Some g => Some (CStrictL g d2) | _ => None end
| DStrict d1 d2, (2::p') => match diag2context d2 p' with
Some g => Some (CStrictR d1 g) | _ => None end
| DPar d1 d2, (1::p') => match diag2context d1 p' with
Some g => Some (CParL g d2) | _ => None end
| DPar d1 d2, (2::p') => match diag2context d2 p' with
Some g => Some (CParR d1 g) | _ => None end
| DSeq d1 d2, (1::p') => match diag2context d1 p' with
Some g => Some (CSeqL g d2) | _ => None end
| DSeq d1 d2, (2::p') => match diag2context d2 p' with
Some g => Some (CSeqR d1 g) | _ => None end
| _, _ => None
end.
(* Example *)
Parameters e1 e2 e3 e4 e5: event.
Definition d : seqDiag := DStrict (DStrict (DE e1) (DE e2))
(DStrict (DE e3) (DE e4)).
Definition og := diag2context d (1::2::nil).
Compute og.
Compute (match og with Some g => Some (fill (DE e5) g) | _ => None end).
- [Coq-Club] the context of sequence diagram, ldou
- Re: [Coq-Club] the context of sequence diagram, Pierre Casteran
- Re: [Coq-Club] the context of sequence diagram, Xavier Leroy
