coq-club - Re: [Coq-Club] the context of sequence diagram
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Pierre Casteran <pierre.casteran AT labri.fr>
  • Cc: ldou AT cs.ecnu.edu.cn, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] the context of sequence diagram
  • Date: Sun, 18 Sep 2011 10:41:52 +0200
Hi,
 Here is a simpler representation of contexts.
Hope this helps,
Pierre
Quoting Pierre Casteran
<pierre.casteran AT labri.fr>:
Hi,
 There are two precisions that should be made :
  I assume a) that the "x" points out to a position where seqDiag is expected
           b) there is exactly one occurrence of "x".
With these assumptions, one can define a type called "context" in the
attached file.
But the best is to have a look at Gérard Huet's proposition for writing
contexts : the zipper data structure.
http://en.wikipedia.org/wiki/Zipper_%28data_structure%29
The best,
Pierre
Quoting
ldou AT cs.ecnu.edu.cn:
hi,guys,
i'm using Coq to formalize the Sequence Diagram. The following inductive type of sequence diagram has been defined:
Inductive seqDiag:Set :=
|DE: event ->seqDiag
|DStrict:seqDiag->seqDiag->seqDiag
|DPar: seqDiag->seqDiag->seqDiag
|DSeq: seqDiag -> seqDiag ->seqDiag.
Then i want to define "context" in Coq. According to our concept, a context is a sequence diagram with one of its fragment replaced by a special symbol x, just like term rewriting. how should i define "context"? any suggestions are appreciated.
Best regards!
窦亮
华东师范大学计算机科学技术系
(Department of Computer Science, East China Normal University)
E-mail:ldou AT cs.ecnu.edu.cn
Parameter event : Type.
Inductive seqDiag:Type :=
|DE: event ->seqDiag
(* type of seqDiags with exactly one hole (where a seqDiag is expected) *)
Inductive context : Type :=
Root : context |
 CStrictL : seqDiag -> context  -> context|
 CStrictR : seqDiag -> context  -> context |
CParL : seqDiag -> context  -> context |
 CParR : seqDiag -> context  -> context |
CSeqL : seqDiag -> context  -> context |
CSeqR : seqDiag -> context  -> context .
(* replacing the hole with d *)
Fixpoint fill (d:seqDiag) (gamma:context) :seqDiag :=
match gamma with
 Root => d |
 CStrictL d2 gamma   => fill ( DStrict d d2) gamma  |
 CStrictR  d1 gamma => fill (DStrict d1 d)  gamma  |
CParL d2 gamma =>  fill  (DPar d d2) gamma |
 CParR  d1 gamma => fill (DPar d1 d) gamma |
CSeqL d2 gamma =>  fill  (DSeq d d2) gamma |
 CSeqR  d1 gamma => fill (DSeq d1 d) gamma
end.
Require Import List.
Open Scope list_scope.
(* building a context from a seqDiag and a path
  1 for left son, 2 for right son *)
(* I should use the monad notations :-) *)
Fixpoint diag2context_aux (d:seqDiag)(p:list nat)(g:context) : option context
 match d,p with
 | d,nil => Some g
 |  DE e, _ => None
 | DStrict d1 d2, (1::p')  => diag2context_aux d1 p' (CStrictL  d2 g)
 | DStrict d1 d2, (2::p')  => diag2context_aux d2 p' (CStrictR  d1 g)
 | DPar d1 d2, (1::p')  => diag2context_aux d1 p' (CParL  d2 g)
 | DPar d1 d2, (2::p')  => diag2context_aux d2 p' (CParR  d1 g)
 | DSeq d1 d2, (1::p')  => diag2context_aux d1 p' (CSeqL  d2 g)
 | DSeq d1 d2, (2::p')  => diag2context_aux d2 p' (CStrictR  d1 g)
 | _,_ => None
end.
Definition  diag2context d path := diag2context_aux d path Root.
(* Example *)
Parameters e1 e2 e3 e4 e5: event.
Definition d : seqDiag := DStrict (DE e1)
                         (DStrict (DStrict (DE e1) (DE e2))
                                  (DStrict (DE e3) (DE e4))).
Definition og := diag2context d (2::1::2::nil).
Compute og.
Compute (match og with Some g => Some (fill (DE e5) g) | _ => None end).
Definition og' := diag2context d (2::2::nil).
Compute (match og' with Some g => Some (fill (DE e5) g) | _ => None end).
