coq-club - [Coq-Club] Debugging Tactics that produce terms
chronological Thread
  • From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Debugging Tactics that produce terms
  • Date: Wed, 21 Sep 2011 11:35:16 -0400
Hello,
I'm wondering if there is a good way to debug tactics that produce terms rather than manipulate goals. Normally I debug tactics with idtac, but it doesn't seem to work with these types of tactics. For example:
Ltac foo x :=
  constr:(1).
Ltac foo_debug x :=
  idtac "hello" ;
  constr:(1).
Goal True.
  match goal with
    | [ |- ?G ] =>
      let k := foo G in
      pose k
  end.
If I call foo then there isn't any problem, but if I call foo_debug, then things don't work. If I change "pose" to "idtac" then foo will cause 1 to be printed and foo_debug will cause "<tactic>" to be printed. Is there something that I could replace idtac with that will print something but not have this behavior?
Thank you.
gregory malecha
http://www.people.fas.harvard.edu/~gmalecha/
