- To: Chad E Brown <cebrown2323 AT yahoo.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Canonical Structures
- Date: Wed, 21 Sep 2011 18:05:39 +0200
On 09/21/2011 05:31 PM, Chad E Brown wrote:
The inference of canonical structure only works for projections. You can see this with the command Print Canonical Projections. that gives: True <- Ppoint ( Prop_ ) Prop <- Pcarrier ( Prop_ ) This means that during the unification process, if it has True and expects and Ppoint ?, it will be able to guess that ? is Prop_. Only the projections (Ppoint and Pcarrier) trigger this inference. In your example, you just ask to unify Prop to PType which just fails -- Laurent |
- [Coq-Club] Canonical Structures, Chad E Brown
- Re: [Coq-Club] Canonical Structures, Laurent Théry
Chad E Brown
Laurent Thery
- Re: [Coq-Club] Canonical Structures, Vladimir Voevodsky
- Re: [Coq-Club] Canonical Structures, Assia Mahboubi
Laurent Thery
Chad E Brown
