- To: Laurent Th�ry <Laurent.Thery AT inria.fr>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Canonical Structures
- Date: Wed, 21 Sep 2011 11:06:02 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:Cc:In-Reply-To:MIME-Version:Content-Type; b=6ndcGJ87E2xDYR0EhvIGXWayWOl0cus2ho23Sz20widsGVJ/62BwJ+XhBTvHE4v4+zjz24bRPYgbReQ1Zeeksh7LindYU95k9HU9a9zKeOkOB3yr3YBKIvwTNqxUAYafqSn6Ju6+KqV1wxHFLNnb0LfIqczSIsxImPAMrBP/Ohg=;
Thanks. I misunderstood how Canonical Structures are used.
I'm trying to work with pointed types (nonempty types with a 'default' element).
It's easy to preserve being pointed under function types. My current way of working with
pointed types in Coq is as follows:
Record PType : Type := mk_PType {
Pcarrier :> Type;
Ppoint : Pcarrier
Definition Prop_ : PType := mk_PType Prop True.
Definition Par (A B:PType) := mk_PType (A -> B) (fun _ => (Ppoint B)).
Notation "A --> B" := (Par A B) (at level 70, right associativity).
Check (fun p:PType -> Prop =>
p ((Prop_ --> Prop_) --> Prop_)).
I'm OK with this solution, but I'd rather write "Prop" instead of "Prop_" and "->" instead of "-->".
Can anyone suggest an alternative?
- Chad
To: Chad E Brown <cebrown2323 AT yahoo.com>
Sent: Wednesday, September 21, 2011 6:05 PM
On 09/21/2011 05:31 PM, Chad E Brown wrote:
Print Canonical Projections.
that gives:
True <- Ppoint ( Prop_ )
Prop <- Pcarrier ( Prop_ )
This means that during the unification process, if it has True and expects and Ppoint ?,
it will be able to guess that ? is Prop_.
Only the projections (Ppoint and Pcarrier) trigger this inference.
In your example, you just ask to unify Prop to PType which just fails
Laurent
The inference of canonical structure only works for projections. You can see this with the commandI'm having trouble getting an easy canonical structure to work as I expect. The final Check below doesn't work.Could someone please let me know what I'm doing wrong, or point me to an appropriate link.
Structure PType : Type := mk_PType {Pcarrier :> Type;Ppoint : Pcarrier}.
Canonical Structure Prop_ : PType := mk_PType Prop True.
Check (fun p:PType -> Prop => p Prop).
- Thanks, Chad
that gives:
Laurent
- [Coq-Club] Canonical Structures, Chad E Brown
- Re: [Coq-Club] Canonical Structures,
Laurent Théry
- Re: [Coq-Club] Canonical Structures, Chad E Brown
Laurent Thery
- Re: [Coq-Club] Canonical Structures, Vladimir Voevodsky
- Re: [Coq-Club] Canonical Structures, Assia Mahboubi
Laurent Thery
Laurent Théry
