- To: coq-club AT inria.fr
- Subject: [Coq-Club] Type A or B?
- Date: Thu, 22 Sep 2011 12:13:02 +0100
Dear all,
I've encountered a puzzling problem in connection with typing of expressions
in the context of a dependent match. Try this:
This specification below is currently accepted by Coq 8.2pl1, where the
'let .. in' that
contains the lines (* 1 *) and (* 2 *) is commented out. Now try to
"comment
it in" again, and comment out one of the two marked lines:
Comment out line (* 1 *) and keep (* 2 *), and you get this error message:
The term "P" has type "R (natS N1') (natS N2')" while it is expected to
have type "R N1 N2".
Comment out line (* 2 *) and keep (* 1 *), and you get this error message:
"P" : "R N1 N2" <-- [this is the 6th term]
The 6th term has type "R N1 N2" which should be coercible to "R (natS N1')
(natS N2')".
So, essentially, we can get two error messages on the form
P has type A which should be B
P has type B which should be A
in a context where the definition of P is unchanged. What's a guy gotta
do? ;-)
Set Implicit Arguments.
CoInductive Nat: Set :=
| natO: Nat
| natS: Nat -> Nat.
CoInductive Nat_lt: Nat -> Nat -> Prop :=
| Nat_lt_O: forall N, Nat_lt natO (natS N)
| Nat_lt_S: forall N1 N2, Nat_lt N1 N2 -> Nat_lt (natS N1) (natS N2).
Parameter R: Nat -> Nat -> Prop.
Hypothesis Hyp: forall N1' N2' N1 N2,
natS N1' = N1 -> natS N2' = N2 -> R N1 N2 -> R N1' N2'.
Definition cast:
forall (R': Nat->Nat->Prop) (N1' N2' N1 N2: Nat) (P: R' N1' N2'),
N1 = N1' -> N2 = N2' -> R' N1 N2.
Proof.
intros. subst N1' N2'. assumption.
Defined.
Implicit Arguments cast [R' N1' N2' N1 N2].
Parameter magic: forall N1 N2, Nat_lt N1 N2.
Parameter eq_magic: forall n1 n1' : Nat, n1 = n1'.
Definition F: forall (N1 N2: Nat) (P: R N1 N2), Nat_lt N1 N2 :=
fun (N1 N2: Nat) (P: R N1 N2) =>
match N1,N2,P return Nat_lt N1 N2 with
| natO , natO , P => magic natO natO
| natO , natS N2' , P => magic natO (natS N2')
| natS N1' , natO , P => magic (natS N1') natO
| natS N1' , natS N2' , P =>
let Hyp' := Hyp (eq_magic (natS N1') N1) (eq_magic (natS N2') N2) in
let P' := Hyp'
(cast P (eq_magic N1 (natS N1')) (eq_magic N2 (natS N2')))
(* 1 *)
P
(* 2 *)
in
magic (natS N1') (natS N2')
end.
Erik Ernst -
eernst AT cs.au.dk
Department of Computer Science, Aarhus University
IT-parken, Aabogade 34, DK-8200 Aarhus N, Denmark
- [Coq-Club] Type A or B?, Erik Ernst
