- To: Vincent Siles <vincent.siles AT ens-lyon.org>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Error: A fixpoint needs at least one parameter.
- Date: Thu, 22 Sep 2011 03:19:05 -0400
Thank you Vincent. My eyes were crossed from too much Coq.
Best,
Randy
On Thu, Sep 22, 2011 at 3:13 AM, Vincent Siles
wrote:
> I'm not on a computer with Coq installed right now (what a shame, I
> know), but if this is an
> exact copy/paste of your problem, I guess the : just after fmlaFV is
> the problem.
> What's happening if you remove it ?
> Best,
> Vincent
> 2011/9/22 Randy Pollack
>Â <rpollack0 AT gmail.com>:
>> What does this error message mean? Consider the following code in Coq
>> 8.3pl2:
>> Reset Initial.
>> Set Implicit Arguments.
>> Inductive sort : Set := Name | Lam.
>> Definition var := (prod nat sort).
>> Inductive trm : sort -> Set :=
>> | ivar : forall (x:var), trm (snd x)
>> | aply : forall (K:trm Lam) (M:trm Lam), trm Lam.
>> Fixpoint trmFV (s:sort) (X:trm s) {struct X} : list var :=
>> match X with
>> | ivar x => cons x nil
>> | aply K M => app (trmFV K) (trmFV M)
>> end.
>> Inductive fsort : Set := prop | aprop.
>> Inductive fmla : fsort -> Set :=
>> | feq: forall (s:sort) (t u: trm s), fmla prop
>> | fand: forall (P Q:fmla prop), fmla prop.
>> Fixpoint fmlaFV: (fs:fsort) (X:fmla fs) {struct X} : list var :=
>> match X with
>> | feq t u => app (trmFV t) (trmFV u)
>> | fand P Q => app (fmlaFV P) (fmlaFV Q)
>> end.
>> The definition of termFV (free variables in a term) is accepted, but
>> the definition of fmlaFV (free variables in a formula) is rejected
>> with the error message above. I don't see the problem.
>> Thanks for any help.
>> Randy
- [Coq-Club] Error: A fixpoint needs at least one parameter., Randy Pollack
- Re: [Coq-Club] Error: A fixpoint needs at least one parameter.,
Vincent Siles
- Re: [Coq-Club] Error: A fixpoint needs at least one parameter., Randy Pollack
Vincent Siles
