- To: Erik Ernst <eernst AT cs.au.dk>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Type A or B? / extra remark
- Date: Thu, 22 Sep 2011 13:58:36 -0400
Erik Ernst wrote:
Den 22/09/2011 kl. 14.14 skrev Adam Chlipala:
Erik Ernst wrote:In fact, I get error messages like 'The term "P" has type "R (natS N1') (natS N2')" in the last branch above when doing 'match N1,N2,P return..' and error messages like 'The term "P" has type "R N1 N2" when doing 'match N1,N2 return..'.
thanks for the quick answer! In fact, this is exactly what I meant when II'm not sure what you mean. The type of [P] _is_ maximally refined above, as
said that the dilemma can be avoided. However, this means that the type of P
will be (R N1 N2) in all branches, which creates a number of problems in the
other branches (just shown as 'magic ..' above).
Can't we have the more specific typing of P in each branch (that we do get
with 'match N1,N2,P return..') without getting into the dilemma?
far as I understand.
I interpreted that to mean that P was typed as indicated, which would
presumably mean that the extra knowledge about N1 and N2 would only appear in
the type of P when it is included in the pattern match, otherwise it always
gets the type (R N1 N2).
I've experimented a little more with this and attached two example files
showing the two situations.
The code I suggested has none of the problems you mention. I'm a bit confused because your new example program demonstrates issues with two ways of writing the pattern match, neither of which is the way that I suggested.
The rules in question here, for dependent pattern matching, are extremely simple, and basically 10 minutes of studying the typing rule can save you from ever being surprised again about the types of variables. The CPDT book explains all this, along with some useful design patterns for fitting the dependency structures of particular programs into the framework that Coq understands.
- [Coq-Club] Type A or B? / extra remark, Erik Ernst
- Re: [Coq-Club] Type A or B? / extra remark,
Adam Chlipala
Erik Ernst
Adam Chlipala
- Re: [Coq-Club] Type A or B? / extra remark, Erik Ernst
Erik Ernst
- Re: [Coq-Club] Type A or B? / extra remark, Adam Chlipala
Erik Ernst
Erik Ernst
Adam Chlipala
Erik Ernst
Adam Chlipala
