coq-club - Re: [Coq-Club] Type A or B? / extra remark
chronological Thread
  • To: Erik Ernst <eernst AT cs.au.dk>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Type A or B? / extra remark
  • Date: Fri, 23 Sep 2011 09:06:47 -0400
Erik Ernst wrote:
In fact, the first quote above is about the two error messages, which used both forms of matching.
The second quote is about the first message I sent to [Coq-Club] about this
issue (subject 'Type A or B?'), and here both situations arise with the
'match N1,N2,P return ..' form.  There was no occurrence of 'match N1,N2
return' in that message, and P is the same variable in both cases.
Sorry!  I didn't read carefully enough.
Now I think I see what you're saying, and it puzzles me, too! What puzzles me in particular is why the rebound [P] would have its type changed. I don't expect that behavior from dependent pattern-matching. I think you've convinced me that this is worth looking into as a bug!
I generally suggest avoiding parallel pattern-matching for tracking dependencies across patterns; I don't think it's meant to support that. But perhaps some (recently added?) feature is trying to allow this but doing it wrong. All parallel matching is compiled to nested single matches, so it's at least clear that the parallel form can't enhance expressivity.
