coq-club - Re: [Coq-Club] Trouble understanding Coq tutorials
chronological Thread
  • To: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
  • Cc: Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Trouble understanding Coq tutorials
  • Date: Tue, 01 Nov 2011 13:40:38 -0400
Andrew Pennebaker wrote:
What prevents me from cheating by assuming enough hypotheses that my goal is reached?
This changes the theorem statement into an implication over your hypotheses. Coq allows asserting axioms that don't appear in a theorem's statement, but the command "Print Assumptions" shows which axioms a proof depends on, so it's pretty easy to understand which facts you're assuming, given a proof as a black box.
How can Coq A) prove that an algorithm for reversing a string is correct and B) prove that a C implementation of the algorithm is correct?
Neither question admits a short answer. Especially the latter is an open question, so far as figuring out the best way to do it.
I would hope that CPDT <http://adam.chlipala.net/cpdt/> gives enough information to answer the first question. (If not, please let me know what's missing!)
Bedrock <http://adam.chlipala.net/bedrock/> is my work-in-progress on tools for verifying C-like programs in Coq.
I'm used to unit testing my programs with QuickCheck <http://www.yellosoft.us/quickcheck>, a probabilistic verifier that brute forces properties such as |propReversible :: String -> Bool| (Haskell notation). How easy would it be to refactor QuickCheck tests into Coq tests?
I assume there is no deep technical challenge in porting QuickCheck to Coq, but we care less about tests when we prove program correctness. I don't know of an extant QuickCheck-for-Coq implementation.
If Coq verifies that my C code is correct, how should I provide "certificates" of verification? Is it enough to provide a code comment to a URL of a .v file?
I don't know of any standard for such a communication. There are many exercises you can carry out to increase your confidence in the correctness of a piece of software, but your question seems somewhat ill-formed without information on who you are trying to convince and of what.
