coq-club - [Coq-Club] Re: Trouble understanding Coq tutorials
chronological Thread
  • To: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
  • Cc: Coq <coq-club AT inria.fr>
  • Subject: [Coq-Club] Re: Trouble understanding Coq tutorials
  • Date: Wed, 02 Nov 2011 08:31:07 -0400
Andrew Pennebaker wrote:
Thanks for the quick reply, CPDT is fascinating. I suspect that other readers similarly wonder, "How does proving an algorithm in Coq certify that my C program is correct?" In future editions, could you include Bedrock examples?
I've never meant to claim that CPDT is meant to explain how to use Coq to verify C-like programs. There are many interesting applications for Coq, and no book could hope to cover them all. I also expect only a minority of CPDT readers are interested in verifying C programs. For these reasons, I'm not planning to add any extra coverage of the topic.
I do expect, however, that Bedrock will grow more documentation at some point. ;)
Have you used QuickCheck <http://www.haskell.org/haskellwiki/Introduction_to_QuickCheck>? I'm not asking to port QuickCheck to Coq, as a brute-force checker would seem redundant to add it to a program verifier. QuickCheck might be a handy tool to check for trivial errors in proofs, but it's by no means a Coq tactic, unless there are negative tactics!
OK, so I think you're saying that QuickCheck users are already writing specifications, so we could hope to write an automatic translator of those specifications into Coq, to give us a head start on deciding which theorems to prove. That seems reasonable. Keep in mind, though, that neither of Haskell and Coq is a subset of the other. In particular, translating Haskell into Coq is tricky, because Coq requires syntactically apparent termination of all programs. I can believe a reasonably effective solution could exist that translates Haskell programs, with their QuickCheck specs, into Coq; but, really, I would recommend doing everything in Coq in the first place, and possibly extracting to Haskell afterward. Writing simple, QuickCheck-style specs isn't very time-consuming.
Hmm, the few programmers who do care about correctness seem to limit themselves to a handful of manual assert() statements. How can we evangelize Coq as an additional testing tool? How exactly can we replace those assertions with Coq proofs?
To clarify my last question, imagine you're a developer at CoolStuff.org. You want to advertise just how safe and correct your software is. Do you, for example, link to a Coq vernacular file on your Products page? If your software is open source, do you link to a vernacular file in a comment section of your code?
Perhaps you would like to read about the idea of proof-carrying code (PCC):
    http://www.eecs.berkeley.edu/~necula/pcc.html
And some more recent work on _foundational_ PCC:
    http://flint.cs.yale.edu/
    http://sip.cs.princeton.edu/projects/pcc/
(Quick answer to part of your question: Coq-based solutions will almost certainly involve distributing .vo files, not .v files.)
