coq-club - [Coq-Club] syntax confusion
chronological Thread
  • From: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: Coq <coq-club AT inria.fr>
  • Subject: [Coq-Club] syntax confusion
  • Date: Wed, 2 Nov 2011 02:30:43 -0400
I want to prove Peirce's Law in Coq, but I'm uncertain of the Coq syntax for each step of the hand proof.
Hand proof:
Peirce's Law: ((p -> q) -> p) -> p
(p -> q) -> p        ASSUMPTION
~(p -> q) | p        ENTAILMENT
    [~(p -> q)]      ASSUMPTION
    ~(~p | q)        ENTAILMENT
    ~~p, ~q          DEMORGAN
    ~~p              AND-ELIMINATION
    p                DOUBLE NEGATION
    [p]              ASSUMPTION
    p                IDENTITY
p                    EXHAUSTION
Qed.
Just to be sure, is my hand proof correct?
Coq Questions:
How do I declare the assumption (p -> q) -> p? In the tutorials, I see a variety of declaration syntaxes using Variables, Inductuctives, Definitions, Theorems, and Lemmas. If I declare one of the those, how do I assume it (e.g., assume that entailment means (a -> b) <-> (b | ~a)?
How do I rewrite terms (e.g. using entailment or DeMorgan declarations)?
How do I go through each possible cases (e.g. ~(p -> q) or p)?
I suspect entailment, DeMorgan's laws, and and-elimination are each included in some Coq tactic library or other, and I would like to know how to leverage them. However, as part of the learning process, my first priority is figuring out how to manually implement them in what should be a relatively simple exercise, proving Peirce's Law.
Cheers,
Andrew Pennebaker
www.yellosoft.us
