- To: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
- Cc: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: syntax confusion
- Date: Wed, 02 Nov 2011 15:50:13 -0400
Andrew Pennebaker wrote:
Oo, the Haskell IO point is apt. So I guess propositional logic tautologies aren't the easiest things to do in Coq? :)
No, they're very easy, either automatically or, after the proper preparation, manually.
I don't mean to be argumentative, but I'm going to start ignoring your questions if you keep ignoring mine about which chunk of CPDT you have read. I truly believe all of your questions on propositional logic so far are answered in CPDT, in reasonably accessible form.
Re: The law of excluded middle
How much of our logic is not based on the law of excluded middle?
Can Peirce's Law be derived without it?
Peirce's law and excluded middle are logically equivalent.
I don't know of any theorem in, for instance, verification of traditional programs that fundamentally relies on classical logic. Rather, I view it as more of a shortcut to avoid proving decidability of some important families of propositions.
- [Coq-Club] syntax confusion, Andrew Pennebaker
- Re: [Coq-Club] syntax confusion, Pierre Casteran
- Re: [Coq-Club] syntax confusion, Marko Malikoviæ
- Message not available
- [Coq-Club] Re: syntax confusion,
Andrew Pennebaker
- Re: [Coq-Club] Re: syntax confusion,
Adam Chlipala
Andrew Pennebaker
Adam Chlipala
Andrew Pennebaker
- Re: [Coq-Club] Re: syntax confusion, Adam Chlipala
- Re: [Coq-Club] Re: syntax confusion, Andrew Pennebaker
- Re: [Coq-Club] Re: syntax confusion, Daniel Schepler
Andrew Pennebaker
Adam Chlipala
Andrew Pennebaker
Adam Chlipala
Andrew Pennebaker
