- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Could [..|some_tactic] be a full-fledged tactic?
- Date: Wed, 2 Nov 2011 13:41:31 +0100
Le Mon, 31 Oct 2011 18:40:41 +0100,
Valentin ROBERT
<valentin.robert.42 AT gmail.com>
a écrit :
> I actually use it a few times (not too many though), and Guillaume
> Gallais' answer definitely helped me.
> Concerning "do num tac", I was probably wrong in its semantics as I
> acknowledged, I just thought I could use it to rewrite something like:
> feed H; [..|feed H]; [..|feed H]; [..|feed H].
it is the case (excepted for the first "feed H;"), but it has the same
problem that you have with what you wanted to do:
...; [..|feed H]; [..|feed H].
| this is applied on each subgoal generated by
> I had actually tried to write the recursive tactic with a decreasing
> nat, but I was missing the proper syntax to do so.
> Thanks to you both.
- Re: [Coq-Club] Could [..|some_tactic] be a full-fledged tactic?, AUGER Cedric
