- To: coq-club AT inria.fr
- Cc: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
- Subject: Re: [Coq-Club] Re: syntax confusion
- Date: Thu, 3 Nov 2011 08:52:25 -0700
Since this has made its way onto coq-club, I decided to post the current
state
of the work at http://people.debian.org/~schepler/coqtut.pdf .
On Wednesday, November 02, 2011 11:45:24 PM Andrew Pennebaker wrote:
> Text:
> Axiom left_id : forall x:G, mult e x = x.
> Axiom left_inv : forall x:G, mult (inv x) x = e.
> Axiom assoc : forall x y z:G,
> mult x (mult y z) = mult (mult x y) z.
> These declarations are fairly straightforward to read.
> Comment:
> I don't know how to read them. In words, what does the left_id axiom mean?
> I read it as "For all x and e, ex = x," which isn't right, or "There exists
> e such that ex = x, for any x," which would have a different form.
> Similarly, I don't know how to read the axiom left_inv. It looks to me like
> "for all x and e, x(x^-1) = e," which isn't right.
> The last axiom is perhaps the most readable: the principle of association,
> that x(yz) = xy(z).
The general answer to these questions: maybe you forgot about the declaration
Parameter e : G.
In other words, e is a *predefined* element of G.
> 1.2 Proof mode
> I see what the proof is doing, but it feels backwards. Can the proof be
> rewritten so that it transforms x * y = x * z into inv x * (x * y) = inv x
> * (x * z), then uses left_inv to reduce that to y = z. Maybe that's what
> the proof is already doing, but the order is tricky.
Hmm, that brings up a good point. Maybe I should explain that in Coq, the
easiest way to construct a proof is "working backward" from the goal using
apply, rewrite, etc. On the other hand, tactics like assert, pose/set, pose
proof, * in H*, etc. let you "work forward" from the hypotheses, which is
probably the more familiar style of argumentation for mathematicians. It's
similar to the difference in functional programming between building a
function
"top down" as a big complex expression, or building a function "bottom up"
using let statements. (And in fact, in Coq's proof terms, the backward
reasoning/forward reasoning difference is exactly the same as the top
down/bottom up definition difference.)
Also, I answer your specific question later, where I introduce the use of
apply f_equal with (f:=fun g:G => inv x * g) in Htocancel.
I just wanted to keep things simple for the first proof.
Daniel Schepler
- Re: [Coq-Club] Re: syntax confusion, (continued)
Andrew Pennebaker
- Re: [Coq-Club] Re: syntax confusion, Adam Chlipala
- Re: [Coq-Club] Re: syntax confusion, Andrew Pennebaker
- Message not available
- Re: [Coq-Club] Re: syntax confusion, Daniel Schepler
Andrew Pennebaker
