- From: Christine Paulin <christine.paulin AT lri.fr>
- To: Randy Pollack <rpollack AT inf.ed.ac.uk>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Induction on size of derivations?
- Date: Fri, 04 Nov 2011 23:59:55 +0100
On 11/04/2011 09:53 PM, Randy Pollack wrote:
I have some inductively defined set, say of terms
Inductive Term : Set := ...
and some inductively defined relation, say of reduction
Inductive Red : Term -> Term -> Prop := ...
I want to do induction on the size of derivations of the Red relation.
So I try to define
Fixpoint RedSize : (M N: Term) (r:Red M N) {struct r} : nat :=
match r with ...
end.
This fails, because Red is a Prop, not a Set. How is this usually done?
One could index the relation Red with size, as is necessary in (simply
typed) HOL, but it seems we should do better with dependent types.
If you do not want to add the size as an extra index, I see two other possibilities:
- define your Red relation in Set as well
- depending on the way Red is defined, it might happen that the size can be computed by case analysis on M and N alone and that the Red relation is only useful to ensure termination of the fixoint construction.
This is the case if after case analysis on M and N you end up in a case where only one of the Red constructors is possible.
So you can write inversion lemmas Red_case1_inv of the form
Red M N -> (discriminating condition on M and N) -> Red M0 N0
by case analysis on the proof of Red M N such that Red_case1_inv H is considered as a subterm of the proof H of Red M N
the proof of the lemma has to be something like
fun H : Red M N =>
match H returns (discriminating condition on M and N) -> Red M0 N0
with (c ..p ) => fun ... => p (* the only applicable constructor, with p a recursive argument)
| _ => fun .... => match (p:False) with end (* all the non possible cases *)
so you can do your fixpoint construction using a recursive call which is structurally decreasing on the proof of Red which can stay in Prop.
I am not sure my explanations are clear enough - if not send me the full problem or I can try to post an example where we use this phenomenon.
Hope it helps, al the best.
Christine
Thanks,
Randy
- [Coq-Club] Induction on size of derivations?, Randy Pollack
- Re: [Coq-Club] Induction on size of derivations?, Christine Paulin
- Re: [Coq-Club] Induction on size of derivations?, Jean-Francois Monin
- Re: [Coq-Club] Induction on size of derivations?, Thorsten Altenkirch
