- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: Randy Pollack <rpollack AT inf.ed.ac.uk>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Induction on size of derivations?
- Date: Sat, 5 Nov 2011 10:22:43 +0800
Hello Randy,
Here is my usual trick, illustrated on a very simple example:
div2 on even numbers. See also the short proof of
(exists n, P n) -> {n:nat | P n} for decidable P,
in ConstructiveEpsilon.v
(* Division by 2 of even numbers *)
Inductive even : nat -> Prop :=
| E0 : even O
| E2 : forall n, even n -> even (S (S n)).
Definition pos n := match n with S _ => True | _ => False end.
Definition testpos n : option (pos n) :=
match n with
| O => None
| S n => Some I
end.
(* Returns a structurally smaller term in *EACH* case of [e] *)
Definition even_pred2 n (e:even n) : pos n -> even (pred (pred n)) :=
match e in even n return (pos n -> even (pred (pred n))) with
| E0 => fun F => match F return (even 0) with end
| E2 _ e0 => fun _ => e0
end.
(* Pitfall:
destruct [n] doesn't work, the structural relationship with [e] is lost;
a structurally smaller [e'] is provided using the another match done
in [even_pred2]
Fixpoint div2 (n: nat)(e: even n) {struct e} : nat :=
match (testpos n) with
| None => O
| Some pn => div2 (pred (pred n)) (even_pred2 n e pn)
end.
Hope this helps,
Jean-Francois
On Fri, Nov 04, 2011 at 04:53:44PM -0400, Randy Pollack wrote:
> I have some inductively defined set, say of terms
> Inductive Term : Set := ...
> and some inductively defined relation, say of reduction
> Inductive Red : Term -> Term -> Prop := ...
> I want to do induction on the size of derivations of the Red relation.
> So I try to define
> Fixpoint RedSize : (M N: Term) (r:Red M N) {struct r} : nat :=
> match r with ...
> end.
> This fails, because Red is a Prop, not a Set. How is this usually done?
> One could index the relation Red with size, as is necessary in (simply
> typed) HOL, but it seems we should do better with dependent types.
> Thanks,
> Randy
- [Coq-Club] Induction on size of derivations?, Randy Pollack
- Re: [Coq-Club] Induction on size of derivations?, Christine Paulin
- Re: [Coq-Club] Induction on size of derivations?, Jean-Francois Monin
- Re: [Coq-Club] Induction on size of derivations?, Thorsten Altenkirch
