- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why this does not compile?
- Date: Sun, 06 Nov 2011 09:31:47 +0100
You forgot to give a parameter of type Set to your my_trans2.
Here is a version that compiles. Note the "About" commands that give
you the type and implicit arguments of your identifiers.
The parameter "set" is given to my_trans2 through the "Generalizable Variables"
command.
It is also possible to give it explicitely.
Pierre
Class Relation {set: Set} := {
About Build_Relation.
Implicit Arguments Build_Relation [set].
Definition compose_relation_classes {set:Set} (f g: @Relation set) :
@Relation set :=
Build_Relation .
About compose_relation_classes.
Generalizable Variables set.
Definition my_trans2 `(r: Relation ) := compose_relation_classes r r = r.
Quoting Victor Porton
<porton AT narod.ru>:
Definition compose_relation_classes {set:Set} (f g: @Relation set) :=
Build_Relation.
Definition my_trans2(r: Relation) := compose_relation_classes r r = r.
Victor Porton - http://portonvictor.org
- [Coq-Club] Why this does not compile?, Victor Porton
- Re: [Coq-Club] Why this does not compile?, Pierre Casteran
