- From: Vincent Siles <vincent.siles AT ens-lyon.org>
- To: Victor Porton <porton AT narod.ru>
- Cc: Carlos Simpson <carlos AT unice.fr>, jose.grimm AT sophia.inria.fr, Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Your theory does not verify
- Date: Sun, 6 Nov 2011 08:39:01 +0100
Did you try to "Set Printing All" to check all the hidden variables
that might not have been instanciated ?
Do you know with which version of Coq this code is known to compile ?
Best,
Vincent
2011/11/6 Victor Porton
<porton AT narod.ru>:
> I downloaded a theory by Carlos Simpson and tried to compile it with Coq
> 83.pl2:
> http://arxiv.ccsd.cnrs.fr/e-print/math/0402336v1
> $ coq_makefile
> $ make
> Makefile:170: .depend: No such file or directory
> rm -f .depend
> coqdep -c -i -I . *.v *.ml *.mli >.depend
> coqdep -c -I . -suffix .html *.v >>.depend
> coqc -q -I . axioms
> coqc -q -I . tactics
> coqc -q -I . set_theory
> File "./set_theory.v", line 278, characters 19-20:
> Error: The reference T was not found in the current environment.
> make: *** [set_theory.vo] Error 1
> It is strange that it refers to some T defined nowhere.
> We need to fix this error.
> In the original theory of Carlos Simpson (as opposed to rewritten theory by
> José Grimm) every type is a set.
> Maybe I'm wrong but it seems to have the convenience that for example
> Set->Set->Prop is a set and there was no need to write explicit type
> conversions.
> May we rewrite some of these libraries of theories to bring back that every
> type is a set?
> Is my proposal viable?
> Victor Porton - http://portonvictor.org
- [Coq-Club] Your theory does not verify, Victor Porton
- Re: [Coq-Club] Your theory does not verify, Vincent Siles
