- To: coq-club AT inria.fr
- Subject: [Coq-Club]
- Date: Tue, 8 Nov 2011 15:59:05 +0100
The trunk generates one more inductive principle than 8.3 did, but the new one
(*_case) seems often to be the same as one of the old ones (*_rect). The
reference manual doesn't explain its purpose. Can anyone clarify?
>>>>>>> Library Top
Inductive paths (A : Type (* Top.1 *)) : A -> A -> Type (* Top.1 *) :=
idpath : forall x : A, @paths A x x
For paths: Argument A is implicit and maximally inserted
For idpath: Argument A is implicit and maximally inserted
For paths: Argument scopes are [type_scope _ _]
For idpath: Argument scopes are [type_scope _]
paths_rect :
forall (A : Type (* Top.3 *))
(P : forall a a0 : A, @paths A a a0 -> Type (* Top.4 *)),
(forall x : A, P x x (@idpath A x)) ->
forall (y y0 : A) (p : @paths A y y0), P y y0 p
paths_ind :
forall (A : Type (* Top.3 *)) (P : forall a a0 : A, @paths A a a0 -> Prop),
paths_rec :
forall (A : Type (* Top.3 *)) (P : forall a a0 : A, @paths A a a0 -> Set),
paths_case :
forall (A : Type (* Top.5 *))
(P : forall a a0 : A, @paths A a a0 -> Type (* Top.6 *)),
- [Coq-Club], Daniel R. Grayson
- Re: [Coq-Club],
Adam Chlipala
- Re: [Coq-Club], Daniel R. Grayson
- Re: [Coq-Club],
Adam Chlipala
