coq-club - Re: [Coq-Club]
Re: [Coq-Club]
chronological Thread
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club]
  • Date: Tue, 8 Nov 2011 14:04:56 -0600
You seem to be right:
    Inductive even : nat -> Type :=
       | even_0 : even O
       | even_SS : forall n:nat, even n -> even (S (S n)).
    Print All.
    even_rect :
    forall P : forall n : nat, even n -> Type,
    P 0 even_0 ->
    (forall (n : nat) (e : even n), P n e -> P (S (S n)) (even_SS n e)) ->
    even_case :
    P 0 even_0 ->
    (forall (n : nat) (e : even n),          P (S (S n)) (even_SS n e)) ->
On Nov 8, 2011, at 9:23 AM, Adam Chlipala wrote:
> Daniel R. Grayson wrote:
>> The trunk generates one more inductive principle than 8.3 did, but the new
>> one
>> (*_case) seems often to be the same as one of the old ones (*_rect).  The
>> reference manual doesn't explain its purpose.  Can anyone clarify?
> I'm guessing the new principle is for case analysis, not induction, based
> on its name.  Have you tested recursive definitions to see if the "case"
> principles indeed omit inductive hypotheses?
