- To: coq-club AT inria.fr
- Subject: [Coq-Club] Re:How to define combination in coq
- Date: Wed, 9 Nov 2011 12:02:40 +0800 (CST)
Hi guys:
Thank you very much for all your guidance.
I read something about list combination in Caml and rewrote the function 'comb' in coq. But I found it didn't meet my demand.
So I try to wrote another function 'combList' and tested it successfully. However, I think my definition of 'combList' is too complex that I used another 3 auxiliary function in the definition. It troubles me a lot when I try to prove some lemmas relates to it . So can you help me to simplify 'combList'? Thanks!
The related codes are in the attachment .
Best,
Phoebe
-------- Forwarding messages --------
Date: 2011-11-06 21:47:43
Subject: How to define combination in coq
Hi guys,
I'm trying to define a function to compute the combination of sets, which pick an element from every set and combine into another set. Let ci be the number of element in set i .The total number of elements in result set will be
¦°ci (0<i<n)
for example
Definition sets :={{"a","b"},{"c","d"},{"e"}}
combination (sets) = {{¡°a¡±,"c","e"},{"a","d","e"},{¡°b¡±,"c","e"},{"b","d","e"}}
Can you give me some guidance about the definition of combination function? Thank you very much.
combine.v
Description: Binary data
- [Coq-Club] Re:How to define combination in coq, ×óÓ£
- Re: [Coq-Club] Re:How to define combination in coq, Andrej Bauer
