- To: Victor Porton <porton AT narod.ru>
- Cc: Thorsten Altenkirch <txa AT Cs.Nott.AC.UK>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] I'm against setoids and pro ZF
- Date: Wed, 9 Nov 2011 10:46:23 -0500 (EST)
I am studying Coq and maybe now may attempt a practical exercise of writing
some theories.
I noticed that the Coq approach is to use setoids. In my opinion, it is silly
and contrary to what we do in informal mathematics.
From my experience, using setoids isn't particularly silly. The same work we do to prove functions respect equivalence relations is exactly the same work that a traditional mathematician does to prove their function defined on a quotient is well-defined.
Furthermore, removing quotients has some nice consequences. Specifically the extensional axiom of choice is distinct from the intensional theorem of choice (see <http://r6.ca/blog/20050604T143800Z.html>).
If you deal with quotients in the traditional way, then the theorem of choice will imply excluded middle, making the system non-constructive:
Proof.
Let P be any proposition.
Consider the relation R (a b: Bool) := {a = b} + {P}. We can prove R is an equivalence relation. Suppose we could make the quotient type Bool/R. We can traditionally prove (*) forall a : Bool/R, {b : Bool | a = [b]/R} where [x]/R is the injection from x : Bool into Bool/R.
Thus from the theorem of choice we can conclude
we can conclude {f : Bool/R -> Bool | forall a:Bool/R, a = [f a]/R}.
We have forall x y : Bool, {x = y} + {~ x = y}, because boolean equality is decidable and thus {f [True]/R = f [False]/R} + {~ f [True]/R = f [False]/R}.
However (f [True]/R = f [False]/R) <-> P
(proof, Suppose P, then R True False holds. Thus [True]/R = [False]/R.
on the other hand, if f [True]/R = f [False]/R, then we
have [True]/R = [f [True]/R]/R = [f [False]/R]/R = [False]/R and thus
R True False, and thus P holds.)
Therefore {P} + {~P}.
Qed.
Now, Thorsten would argue that this traditional approach to quotients is wrong (and I would agree). Doing quotients properly in type theory would disallow step (*) and instead only admit
forall a : Bool/R, [[{b : Bool | a = [b]/R}]] where [[P]] is a squash type, which is the type P quotiented so that all values are identified. Now the theorem of choice won't apply.
The problem with quotients done properly is that you can never escape from them to choose a representative. Now you might think that this is exactly the point of using quotients; however such strict adherence to quotients severely limits your ability to compute.
Example (1) If you define the real numbers as a quotient you can never approximate a real number by a rational number because all computable functions from real numbers to rational numbers have to be continuous, which means constant in this case. Thus you could never display any results of real number computation. By using setoids you still have the option to write disrespectful functions that allow you to pick an rational approximation that depends on the particular representative and thus allowing you to display decimal approximations.
Example (2) If you define the real numbers as a quotient then you cannot extend a unit vector in R^3 to an orthonormal basis in R^3 that includes it. Again, with proper quotients, all constructive functions from R^3 to an orthonormal basis would have to be continuous. By the no-hairy-ball-can-be-combed-smooth theorem, such a continuous function is impossible. Again, if we use setoids we have an option of breaking free of the equivalence relation and create a disrespectful function from R^3 to an orthonormal basis that includes it. The construction of such a basis will depend on the choice of representative, but the construction can be carried out.
From these examples (and I'm sure there are many more), I conclude that using setoids is the most flexible approach. Using traditional quotients makes your system non-constructive, and using proper quotients limits your ability to compute.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] I'm against setoids and pro ZF, Victor Porton
- Re: [Coq-Club] I'm against setoids and pro ZF,
Adam Chlipala
- Re: [Coq-Club] I'm against setoids and pro ZF, roconnor
- Message not available
Bruno Barras
- Re: [Coq-Club] I'm against setoids and pro ZF, Bruno Barras
Bruno Barras
Matthieu Sozeau
- Re: [Coq-Club] I'm against setoids and pro ZF, Thorsten Altenkirch
- Re: [Coq-Club] quotients,
Carlos Simpson
- Re: [Coq-Club] quotients, Andrew Cave
roconnor
Carlos Simpson
roconnor
Carlos Simpson
- Re: [Coq-Club] quotients, roconnor
- Re: [Coq-Club] quotients, Bas Spitters
- Re: [Coq-Club] quotients, Andrej Bauer
- Re: [Coq-Club] quotients, Peter Vincent Homeier
Carlos Simpson
roconnor
Carlos Simpson
Carlos Simpson
Adam Chlipala
