coq-club - Re: [Coq-Club] Non-uniform parameters in inductive definitions?
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Non-uniform parameters in inductive definitions?
  • Date: Wed, 16 Nov 2011 15:41:56 +0100
On 11/16/2011 11:50 AM, Peter LeFanu Lumsdaine wrote:
I’m rather confused about what should happen when parameters occur
non-uniformly in constructors in inductive definitions.  The manual
says (version 8.3pl1, section 4.5, p111):
Since COQ version 8.1, there is no restriction about parameters in the types
of
arguments of constructors. The following definition is valid:
----8<---
Inductive list’ (A:Set) : Set :=
  | nil’ : list’ A
  | cons’ : A ->  list’ (A->A) ->  list’ A.
----8<---
When I run this definition through Coq, it does accept it, but seems
to deal with it just by treating A as an index rather than a
parameter.  That is, the resulting recursor has type
----8<---
list'_rect
      : forall P : forall A : Set, list' A ->  Type,
        (forall A : Set, P A (nil' A)) ->
        (forall (A : Set) (a : A) (l : list' (A ->  A)),
         P (A ->  A) l ->  P A (cons' A a l)) ->
        forall (A : Set) (l : list' A), P A l
----8<---
which is what I’d expect with A an index — it is not itself
universally quantified over all A:Set, but instead requires that the
predicate into which we eliminate is so quantified.  (And it’s the
same as what you get if you rewrite the definition with A as an index,
[Inductive list' : Set ->  Set := …].)
Putting what Matthieu already said with my own words:
non-uniform parameters behave
(1) like normal indices w.r.t. recursive schemes
(2) like parameters w.r.t. dependent pattern-matching (check out list'_case)
With regular parameters, each instance can be defined independently from the other instances. This does not hold with non-uniform parameters (list' nat refers to list' (nat->nat)). The recursive scheme cannot be expressed for one particular instance.
For pattern-matching, the knowledge of the non-uniform parameters can be propagated to the pattern variables, in the same way as we do for regular parameters.
I would also be interested in any pointers to the literature on
non-uniform parameters — I haven’t been able to find any.
This has been proposed and implemented by Christine Paulin, but I don't think she published anything about that. The initial guess was that non-uniform parameters could be interpreted in terms of usual inductive definitions. The formal study of inductive definitions I've been working on uncovered (solvable) difficulties to prove their soundness, but my conclusion is that they don't drastically strengthen the theory (if they ever do).
The problem is that the translation of list' with indices gives:
Inductive list’ : Set->Set :=
  | nil’ : forall A:Set, list’ A
  | cons’ : forall A:Set, A ->  list’ (A->A) ->  list’ A.
which is impredicative and impredicative inductive definitions (replacing Set with Type) leads to paradoxes. Here, there's no paradox because the A argument of constructors is not free. Rather, it is uniquely determined by the type.
But there's still an issue when studying this feature in general.
Consider
Inductive I (X:Set) : Set :=
  C : X -> I X.
(You could add a constructor D : I (X->X) -> I X to prevent X from being a real parameter but it has not much to do with my point.)
With standard inductive types, you can deal with indices by first defining a non-dependent datatype and then you can define a predicate that rules out the raw values that do not respect the index constraints. For instance, the non-dep datatype associated to vector is list, and it's fairly easy to write a predicate that enforces the size constraint.
With I, the problem is that the set of raw values is too big (and doesn't fit in Set): basically I X is a copy of X, so the union of all values of I X is the whole Set universe. The extra work is to show that each subset I X for a particular X:Set form a small set. This is so because the set of subterms (the argument of the D constructor) form a small set, and this is hereditary (the union of X with X->X, (X->X)->X->X,... is a small set). This very last argument hasn't been fully formalized yet.
Bruno.
Bruno Barras                    Typical team - INRIA Saclay
LIX - Ecole Polytechnique       91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57          Fax: +33 1 69 33 30 14
