coq-club - Re: [Coq-Club] Non-uniform parameters in inductive definitions?
chronological Thread
  • To: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>
  • Cc: Peter LeFanu Lumsdaine <p.l.lumsdaine AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Non-uniform parameters in inductive definitions?
  • Date: Mon, 28 Nov 2011 21:31:17 +0100
Hi Thorsten,
sorry I did not see your answer right away...
On 11/24/11 4:42 PM, Altenkirch Thorsten wrote:
In a predicative setting:
Uniform datatypes can be reduced to W-types (in an extensional setting).
However, it is not clear wether we can do this for non-uniform datatypes.
(Actually I think we can't).
If this is true then do non-uniform datatypes extend the strength of the
system?
I think so.
In my paper
  Semi-continuous Sized Types and Termination
Logical Methods in Computer Science, Volume 4, Issue 2, Paper 3. CSL'06 special issue.
  http://www2.tcs.ifi.lmu.de/~abel/publications.html#lmcs07
in Example 3.1 I explain how to encode an infinite sequence of number classes into one non-uniform data type:
  NCn = µ Fn          , where
  F0 X   = 1              and
  Fn+1 X = Fn X + (µFn → X ).
So basically, the n+1st number class is a tree branching over the nth number class.
You can turn that into one nested data type:
  µλY λF. 1 + (µF → Y (λX. F X + (µF → X ))).
Herein,
  F : * -> *
  Y : (* -> *) -> *
Does this make sense?
Cheers,
Andreas
And is there a universal type like W covering non-uniform operators?
Thorsten
On 24/11/2011 08:55, "Andreas
Abel"<andreas.abel AT ifi.lmu.de>
  wrote:
If you want some literature on this, I can advertise the paper by Ralph
and myself:
Fixed Points of Type Constructors and Primitive Recursion
Andreas Abel and Ralph Matthes
Computer Science Logic, 18th International Workshop, CSL 2004, 13th
Annual Conference of the EACSL
Karpacz, Poland, September 2004. LNCS 3210,  Springer.
http://www2.tcs.ifi.lmu.de/~abel/publications.html#csl04
It is about Fomega, no dependencies, but the principles stay the same
for CC.
Cheers,
Andreas
On 21.11.11 2:36 AM, Peter LeFanu Lumsdaine wrote:
On Wed, 16 Nov 2011, Bruno Barras wrote:
Putting what Matthieu already said with my own words:
non-uniform parameters behave
(1) like normal indices w.r.t. recursive schemes
(2) like parameters w.r.t. dependent pattern-matching (check out
list'_case)
Many thanks to those who replied both on- and off-list; this makes a
lot of sense now.
Best,
Peter.
Andreas Abel<><       Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
This message and any attachment are intended solely for the addressee and may
contain confidential information. If you have received this message in error,
please send it back to me, and immediately delete it.   Please do not use,
copy or disclose the information contained in this message or in any
attachment.  Any views or opinions expressed by the author of this email do
not necessarily reflect the views of the University of Nottingham.
This message has been checked for viruses but the contents of an attachment
may still contain software viruses which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
Andreas Abel  <><      Du bist der geliebte Mensch.
