- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: Victor Porton <porton AT narod.ru>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A beginner question: Prove A<B & B<C -> A<C
- Date: Fri, 18 Nov 2011 19:46:23 +0100
There are several way to understand your beginner's question.
1) Are you asking for help to understand subtleties of the declarative mode ?
2) Are you failing to produce a proof of your theorem using the
declarative mode (that is, you were not able to produce a proof with
"enough justification", which is blocking for you) ?
3) Are you failing to produce a proof of your theorem at all (a real
beginner's question)?
if 1), then I leave people more versed in the declarative mode to answer.
if 2), then the script attached works, but I would suggest to re-read
the manual: it really helps. Or to use the usual proof mode.
if 3), then re-read any tutorial.
Cheers,
thomas
Variable A B C : Set.
Variable sub : Set -> Set -> Prop.
Axiom ax1: (sub A B).
Axiom ax2: (sub B C).
Axiom transitive : forall A B C, sub A B -> sub B C -> sub A C.
Theorem thm: (sub A C).
proof.
thus thesis by (transitive _ _ _ ax1 ax2).
end proof. Qed.
On Fri, Nov 18, 2011 at 5:47 PM, Victor Porton
wrote:
> The following source file does not verify, saying "Warning: Insufficient
> justification."
> What is my error?
> Require Import sset1.
> Variable A B C: Set.
> proof.
> š(*thus thesis by ax1, ax2, sub_trans using auto.*)
> šthus thesis by ax1, ax2 using apply sub_trans.
> end proof. Qed.
> BTW, here the lemma from GAIA which I use:
> Lemma sub_trans : forall a b c, sub a b -> sub b c -> sub a c.
> Proof. by move => a b c sab sbc x xa; apply sbc; apply sab. Qed.
> Victor Porton - http://portonvictor.org
- [Coq-Club] A beginner question: Prove A<B & B<C -> A<C, Victor Porton
- Re: [Coq-Club] A beginner question: Prove A<B & B<C -> A<C,
Victor Porton
- Re: [Coq-Club] A beginner question: Prove A<B & B<C -> A<C, Victor Porton
- Re: [Coq-Club] A beginner question: Prove A<B & B<C -> A<C, Thomas Braibant
Victor Porton
