coq-club - Re: [Coq-Club] A beginner question: Prove A<B & B<C -> A<C
chronological Thread
  • To: Thomas Braibant <thomas.braibant AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] A beginner question: Prove A<B & B<C -> A<C
  • Date: Fri, 18 Nov 2011 23:24:55 +0400
  • Envelope-from: porton AT yandex.ru
(Thomas Braibant, it is a modified version of the email I've sent to you. Now
I also send it to the mailing list which I forgotten in my previous email.)
18.11.2011, 22:46, "Thomas Braibant"
<thomas.braibant AT gmail.com>:
> There are several way to understand your beginner's question.
> 1) Are you asking for help to understand subtleties of the šdeclarative
> mode ?
No, I understand that tactics here would be similar for the declarative mode
and plain tactic scripts.
> 2) Are you failing to produce a proof of your theorem using the
> declarative mode (that is, you were not able to produce a šproof with
> "enough justification", which is blocking for you) ?
Yes, I am failing.
> 3) Are you failing to produce a proof of your theorem at all (a real
> beginner's question)?
Yes, I'm failing to produce a proof of my theorem at all. (Maybe I would be
able to write a long highly manual proof, but that's irrelevant.)
> if 1), then I leave people more versed in the declarative mode to answer.
Not the case.
> if 2), then the script attached works, but I would suggest to re-read
> the manual: it really helps. Or to use the usual proof mode.
> if 3), then re-read any tutorial.
Thanks I am to read stuff about tactics.
I found an other trouble:
This does not compile:
Require Import sset1.
Variable A B C : Set.
(*Variable sub : Set -> Set -> Prop.*)
Axiom ax1: (sub A B).
Axiom ax2: (sub B C).
(*Axiom sub_trans : forall a b c, sub a b -> sub b c -> sub a c.*)
Theorem thm: (sub A C).
proof.
thus thesis by (sub_trans _ _ _ ax1 ax2).
end proof. Qed.
It compiles only in the case if I add @ to sub_trans:
proof.
thus thesis by (@sub_trans _ _ _ ax1 ax2).
end proof. Qed.
I wonder why now it requires @, as sub_trans defined in sset1.v (in GAIA)
seems to not have any implicit arguments. Why @ is required?
> Axiom transitive : forall A B C, sub A B -> sub B C -> sub A C.
> proof.
> thus thesis by (transitive _ _ _ ax1 ax2).
> end proof. Qed.
> On Fri, Nov 18, 2011 at 5:47 PM, Victor Porton
> <porton AT narod.ru>
>  wrote:
>> šThe following source file does not verify, saying "Warning: Insufficient
>> justification."
>> šWhat is my error?
>> š[[[
>> šRequire Import sset1.
>> šVariable A B C: Set.
>> šAxiom ax1: (sub A B).
>> šAxiom ax2: (sub B C).
>> šTheorem thm: (sub A C).
>> šproof.
>> šš(*thus thesis by ax1, ax2, sub_trans using auto.*)
>> ššthus thesis by ax1, ax2 using apply sub_trans.
>> šend proof. Qed.
>> š]]]
>> šBTW, here the lemma from GAIA which I use:
>> šLemma sub_trans : forall a b c, sub a b -> sub b c -> sub a c.
>> šProof. by move => a b c sab sbc x xa; apply sbc; apply sab. Qed.
>> š--
>> šVictor Porton - http://portonvictor.org
