- To: ldou AT cs.ecnu.edu.cn
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] again, about ListSet , MSets or FSets
- Date: Sat, 19 Nov 2011 09:40:38 -0800
On Friday, November 18, 2011 11:23:56 PM
wrote:
> Hi,Daniel
> I'm very appreciate your reply. your solution is very helpful. but i am
> not familiar with Program Fixpoint. when i copy your codes to Coq, i got
> the error information. Any suggestion? Thanks a lot!
> Section bringToFrontOfList.
> Variable A:Type.
> Hypothesis Aeq_dec : forall x y:A, {x = y} + {x <> y}.
> Lemma In_to_front: forall {A} (a:A) (l:list A),
> In a l -> exists l':list A, Permutation l (a::l').
> Proof.
> Admitted. (*needs to prove*)
> Program Fixpoint bring_to_front (a:A) (l:list A) :
> In a l -> { l':list A | Permutation l (a::l') } :=
> match l with
> | b :: l' => if (Aeq_dec a b) then l' else
> b :: bring_to_front a l' _
> | nil => nil
> end.
> End bringToFrontOfList.
> Error:
> In environment
> A : Type
> Aeq_dec : forall x y : A, {x = y} + {x <> y}
> bring_to_front : Tactics.fix_proto
> (forall (a : A) (l : list A),
> In a l -> {l' : list A | Permutation l (a :: l')})
> a : A
> l : list A
> b : A
> l' : list A
> Heq_l : b :: l' = l
> H : a = b
> The term "l'" has type "list A" while it is expected to have type
> "In a (b :: l') -> {l' : list A | Permutation (b :: l') (a :: l')}".
Sorry, I guess I forgot to consume the "In a l" argument. This version
compiles for me:
Require Export List.
Require Export Permutation.
Require Import Program.
Variable A:Type.
Hypothesis A_eq_dec: forall x y:A, { x = y } + { x <> y }.
Lemma In_to_front: forall (a:A) (l:list A),
Proof.
intros.
induction l; simpl in H.
contradiction.
destruct H as [[]|].
exists l; apply Permutation_refl.
destruct (IHl H) as [l'].
exists (a0 :: l').
apply Permutation_trans with (a0 :: a :: l');
constructor; trivial.
Qed.
fun _ =>
match l with
| b :: l' => if (A_eq_dec a b) then l' else
end.
Next Obligation. Proof.
destruct H; congruence || assumption.
Qed.
apply Permutation_trans with (b :: a :: x);
Defined.
Require Import ExtrOcamlBasic.
Extraction bring_to_front.
Daniel Schepler
- Re: [Coq-Club] again, about ListSet , MSets or FSets, ldou
- Re: [Coq-Club] again, about ListSet , MSets or FSets, Daniel Schepler
