- From: Jesper Louis Andersen <jesper.louis.andersen AT gmail.com>
- To: Victor Porton <porton AT narod.ru>
- Cc: Daniel Schepler <dschepler AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Impossible to compare dependent records? :-(
- Date: Mon, 21 Nov 2011 00:11:00 +0100
2011/11/20 Victor Porton
<porton AT narod.ru>:
> So I fail to understand what eq_rect means. Could you explain?
The simplest solution is to ask Coq:
Coq < About eq_rect.
eq_rect :
forall (A : Type) (x : A) (P : A -> Type), P x -> forall y : A, x = y -> P y
Argument A is implicit
Argument scopes are [type_scope _ _ _ _ _]
eq_rect is transparent
Expands to: Constant Coq.Init.Logic.eq_rect
This tells you it is equivalent to eq_rect_r. There may be a reason
for having the alternative name, but I don't know it unfortunately. My
guess is the information can be found out by reading the source code.
Other likewise Vernacular commands are to be found here in the manual:
http://coq.inria.fr/doc/Reference-Manual009.html
Especially the Search-commands are useful. They allow you to hunt for
specific definitions and such in "reverse". You know there ought to be
a theorem X, but you only know its statement, not its name for
instance.
J.
- [Coq-Club] Impossible to compare dependent records? :-(, Victor Porton
- Re: [Coq-Club] Impossible to compare dependent records? :-(,
Andrej Bauer
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Adam Chlipala
Daniel Schepler
Victor Porton
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Jesper Louis Andersen
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Daniel Schepler
Victor Porton
Victor Porton
Victor Porton
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Carlos Simpson
Victor Porton
Andrej Bauer
