- To: Andrej Bauer <andrej.bauer AT andrej.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Impossible to compare dependent records? :-(
- Date: Tue, 22 Nov 2011 23:33:20 +0400
- Envelope-from: porton AT yandex.ru
One more novice question:
Can we prove the following theorem as a consequence of equal_foo?
Theorem thm (u v : Foo): (a u = a v -> u = v).
22.11.2011, 23:11, "Victor Porton"
<porton AT narod.ru>:
> 20.11.2011, 18:07, "Andrej Bauer"
>Â <andrej.bauer AT andrej.com>:
>> šYou are flooding the list with trivialities. In addition, your
>> šmessages are arrogant because you keep saying things like "Coq can't
>> šcompare dependent records" where in reality the source of trouble is
>> š(in most cases) your ignorance. There is nothing wrong with being
>> šignorant, and we're happy to help, but not if you keep implying that
>> ševeryone on this list, the designers of Coq included, are so dumb that
>> šthey can't even get the basic things right and that the design
>> šdecisions made in Coq are obviously bad. (This _is_ what you are
>> šimplying, even if you are not aware of it.)
> I don't say that Coq design decisions are bad. I understand that Coq is
> built on a set of highly orthogonal principles. Following orthogonal
> principles is good.
> But excuse me to ask one more dumb question with suspicion that in the
> current version of Coq there are some deficiency. If I don't ask, I can't
> be 100% sure.
> Dear Andrej Bauer, I've read your code (below) and I somehow understand
> (honestly not 100%) its idea. I am going to put it into real use.
> But the question arises: Should I repeat it every time I introduces a
> dependent structure?
> Can it be put into a coherent way for every dependent record I declare,
> allowing to not repeat the same proof each time?
> I don't thing anything is wrong, just I am confused with this question/
>> šWhat version of Coq are you using?
> 8.3pl2
>> šAnyhow, you can of course compare dependent records, but you must
>> štransport the dependent component of one record along the proof of
>> šequality so that things typecheck, i.e.:
> I repeat (a little modified for simplicity) code by Andrej Bauer:
> Parameter A : Set.
> Parameter B : A -> Prop.
> Structure Foo := mkFoo { a : A; b : B a }.
> Definition tran {u v : Foo} (p : a u = a v) : B (a u) -> B (a v).
> Proof.
> ššinduction p.
> ššauto.
> Defined.
> (*Print tran.*)
> Lemma equal_foo (u v : Foo) (p : a u = a v) : tran p (b u) = b v -> u = v.
> Proof.
> ššintro H.
> ššdestruct u as [x y].
> ššdestruct v as [s t].
> ššsimpl in * |- *.
> ššdestruct p.
> ššsimpl in H.
> ššrewrite H.
> ššreflexivity.
> Qed.
>> šLemma equal_foo says that the dependent records u and v are equal,
>> šprovided that their first components are equal, and the second
>> šcomponent of u is equal to the second component of v, after we have
>> šconverted it from type B (a u) to type B (a v) via the proof p of
>> šequality a u = a v.
> Victor Porton - http://portonvictor.org
- [Coq-Club] Impossible to compare dependent records? :-(, Victor Porton
- Re: [Coq-Club] Impossible to compare dependent records? :-(,
Andrej Bauer
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Adam Chlipala
Daniel Schepler
Victor Porton
Jesper Louis Andersen
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Daniel Schepler
Victor Porton
Victor Porton
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Victor Porton
- Re: [Coq-Club] Impossible to compare dependent records? :-(, Carlos Simpson
Andrej Bauer
