coq-club - Re: [Coq-Club] RE: Program obligations leaving out key hypotheses
chronological Thread
  • To: "Alexander, Samuel" <alexander AT math.ohio-state.edu>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] RE: Program obligations leaving out key hypotheses
  • Date: Mon, 21 Nov 2011 10:47:34 +0100
I don't expect Program with measure to be a complete algorithm.
In your example, it is hard to automatically figure out the right structure.
So, I think one should do some work to make it to work correctly.
The following is my solution.
I hope this helps.
Program Fixpoint gmap {A B : Type} (l: list A) (f: forall a (IN: In a
l), B) : list B :=
  match l return (forall a (IN: In a l), B) -> list B with
  | nil => fun _ => nil
  | a :: t => fun f => f a _ :: gmap t (fun _ IN => f _ (or_intror _ IN))
  end f.
Program Fixpoint Interp (T : Term) (s : Assignment) {measure (Depth T)} : nat
  match T with
  | var x => s x
  | const c => c
  | apply f Ts => M f (gmap Ts (fun A IN => Interp A s))
  | varapply G u v x => M G (gmap (VarSub u x (S (Interp v s))) (fun A
IN => Interp A s))
  end.
Best,
Gil
On Mon, Nov 21, 2011 at 5:12 AM, Alexander, Samuel
 wrote:
>>> Just removing "in ... return ..." seems to work.
>> I am wondering why it doesn't work when "in ... return..." is used.
> To make matters even more mysterious, the definition at the bottom of the
> following file suffers the same problem, and this time just messing around
> with "in ... return ..." no longer fixes it:
> http://www.math.osu.edu/~alexander/variadic/variadic3.txt
> -Sam Alexander
