- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Gyesik Lee <gslee AT hknu.ac.kr>
- Cc: "alexander AT math.ohio-state.edu" <alexander AT math.ohio-state.edu>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] RE: Program obligations leaving out key hypotheses
- Date: Tue, 22 Nov 2011 17:47:42 +0100
Hi,
Le 21 nov. 2011 à 04:11, Gyesik Lee
a écrit :
>> Just removing "in ... return ..." seems to work.
> I am wondering why it doesn't work when "in ... return..." is used.
Adding in ... return deactivates the special treatment of pattern-matching of
Program, e.g the implicit threading of equalities in the branches.
>> I was able to fix it by adding "Require Coq.Logic.JMeq" (note just one
>> .JMeq
>> instead of .JMeq.JMeq) to the top of the file. Have we just discovered a
>> minor
>> typo in Coq?
> By "Require Coq.Logic.JMeq" you are importing the JMeq module,
> and that module includes the inductive type JMeq.
> I guess, the JMeq type is implicitly used in dealing with your case.
Indeed, JMeq might be used during the compilation of pattern-matching, that's
why it is required. I think the anomaly turned into a nicer error message in
the trunk. Might still be the wrong error message though :)
-- Matthieu
- [Coq-Club] RE: Program obligations leaving out key hypotheses, alexander
- Re: [Coq-Club] RE: Program obligations leaving out key hypotheses,
Gyesik Lee
- RE: [Coq-Club] RE: Program obligations leaving out key hypotheses, Alexander, Samuel
- Re: [Coq-Club] RE: Program obligations leaving out key hypotheses, Matthieu Sozeau
Gyesik Lee
