coq-club - Re: [Coq-Club] apply @lemma
chronological Thread
  • From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
  • To: Michael Shulman <mshulman AT ucsd.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] apply @lemma
  • Date: Mon, 21 Nov 2011 22:29:08 +0100
Hi Micheal:
There are two types of implicit arguments: the "normal" ones, and the
"maximally inserted". The intuition is this: the normal ones are
automatically added (say, replace by _) by the system when an argument
after them is provided. The maximally inserted ones are added as soon
as all the arguments before are given. Let us see an example :)
Definition fst A B (ab:A * B) := let (a, _) := ab in a.
fst is of type forall A B : Type, A * B -> A
Say A and B are implicit:
Implicit Arguments fst [A B].
Then this works:
Eval compute in (fst (true, 5)).
and computes true: because the argument ab (here (true, 5)) is given,
A and B are "inserted" (it's equivalent to @fst _ _ (true, 5))
Now what about
Require Import List.
Notation "[ ]" := nil.
Notation "[ a ; .. ; b ]" := (a :: .. (b :: []) ..).
Eval compute in (map fst [(true, 5); (false, 6)]).
It fails, saying:
Error: The term "fst" has type "forall A B : Type, A * B -> A"
 while it is expected to have type "?21 -> ?22".
Here fst is by itself, without arguments: so A and B are *not*
inserted (remember that Implicit Arguments are inserted when an
argument following them is provided). So it has the "nude" type of
fst, which is not of the form _ -> _, and therefore cannot be an
argument of map.
Solution? The first is to go for
Eval compute in (map (@fst _ _) [(true, 5); (false, 6)]).
The second is to use maximally inserted arguments:
Implicit Arguments fst [[A] [B]].
Here it works, because A and B are immediately added.
So now what is the problem with apply? Basically, when you have
apply foo
is like
apply (@foo _ _).
But the systems tries to type (@foo _ _) *before* giving to apply
(which is good if you type something like "apply (5 false)", you
directly have a type error on the application of a nat to a bool). But
there, there is no context to type the _. Hence the type error.
If the arguments are only implicit, it's like typing "apply @foo",
which is typable.
Hopes this helps
Cheers, Alexandre
On Mon, Nov 21, 2011 at 7:08 PM, Michael Shulman
 wrote:
> Hi,
> What is the difference between
> apply lemma.
> and
> apply @lemma.
> ?  I have encountered a few situations where the former fails but the
> latter succeeds.  This confuses me, because in both cases all the
> arguments of lemma (implicit or non-implicit) have to be deduced from
> context.  Is the first one somehow trying to guess the implicit
> arguments too soon or without enough information?
> Thanks!
> Mike
