- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Re: apply @lemma
- Date: Thu, 24 Nov 2011 20:34:36 -0800
I have managed to extract a fairly small example which exhibits the
behavior I mentioned. There are no typeclasses or coercions.
Definition compose {A B C} (g : B -> C) (f : A -> B) (x : A) := g (f x).
Axiom reflect : Type -> Type.
Axiom reflect_factor : forall {X Y}, (X -> Y) -> (reflect X -> Y).
Axiom map_to_reflect : forall X, X -> reflect X.
Definition reflect_functor {X Y} (f : X -> Y) : reflect X -> reflect Y
:= reflect_factor (compose (map_to_reflect Y) f).
Axiom reflect_factoriality : forall {X Y Z} (g : Y -> Z) (f : X -> Y)
(rx : reflect X),
(reflect_factor g (reflect_functor f rx)) = (reflect_factor (compose g f)
rx).
Definition reflect_functoriality {X Y Z} (g : Y -> Z) (f : X -> Y) (rx
: reflect X) :
(reflect_functor g (reflect_functor f rx)) = (reflect_functor
(compose g f) rx).
Proof.
apply @reflect_factoriality.
Defined.
In the proof above, "apply reflect_factoriality" fails with the
message 'Error: Impossible to unify "Y" with "Z".' whereas "apply
@reflect_factoriality" succeeds. Can anyone explain the difference?
Thanks!
Mike
On Mon, Nov 21, 2011 at 10:08, Michael Shulman
<mshulman AT ucsd.edu>
wrote:
> Hi,
> What is the difference between
> apply lemma.
> and
> apply @lemma.
> ? I have encountered a few situations where the former fails but the
> latter succeeds. This confuses me, because in both cases all the
> arguments of lemma (implicit or non-implicit) have to be deduced from
> context. Is the first one somehow trying to guess the implicit
> arguments too soon or without enough information?
> Thanks!
> Mike
- [Coq-Club] apply @lemma, Michael Shulman
- Re: [Coq-Club] apply @lemma,
Alexandre Pilkiewicz
Michael Shulman
- Re: [Coq-Club] apply @lemma, Alexandre Pilkiewicz
Arnaud Spiwack
Michael Shulman
- Re: [Coq-Club] apply @lemma, AUGER Cedric
Michael Shulman
Michael Shulman
- [Coq-Club] Re: apply @lemma, Michael Shulman
- Re: [Coq-Club] Re: apply @lemma,
Matthieu Sozeau
- Re: [Coq-Club] Re: apply @lemma, Michael Shulman
Matthieu Sozeau
