coq-club - Re: [Coq-Club] Identity with Rpower?
chronological Thread
  • From: Pierre Corbineau <Pierre.Corbineau AT imag.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Identity with Rpower?
  • Date: Tue, 29 Nov 2011 17:24:24 +0100
  • Mailscanner-null-check: 1323188354.20784@H2pLJBWwRC/Dd+eDAzWGuA
  • Organization: Verimag
Hi,
The bug is known (Bug 2447) : the C-zar default automation uses congruence and congruence has a bug in the proof-generation code which makes it hang.
This bug is highly non-trivial: it involves problems with cycles in a pointer graph. I will fix it when I have Copious Free Time(TM).
The workaround for now would be to type something like:
then ((Rpower x 1) = x) by Rpower_1 using apply Rpower_1;auto.
The "then" instead of "have" is necessary here: you need x>0. The 'by Rpower_1' can be omited (but only because Rpower_1 is not a local hypothesis).
Cheers,
Pierre
On 11/28/2011 04:27 PM, John Nicol wrote:
Hi there,
I'm new to Coq, so this is probably obvious.
I'm trying to use Rpower declaratively (I don't want to do an
imperative proof, so I haven't tested that).  Coq starts churning
every time I do so, and eventually I run out of patience.  (Also: the
IDE completely locks up, so I can't click interrupt.)
I've isolated the problem I'm having to the following test lemma,
which is I think a restatement of Rpower_1, which I think is also in
R_scope.  (Theorem Rpower_1 : forall x:R, 0<  x ->  x ^R 1 = x.)
Open Local Scope R_scope.
Lemma test_Rpower_1:
   forall x:R,
   x>  0 ->  (Rpower x 1) = x.
proof.
   let x:R be such that (x>  0).
have ((Rpower x 1) = x) by Rpower_1.  (*This line causes problems. *)
end proof.
Qed.
What am I missing?
Thanks,
John
Pierre Corbineau          |
VERIMAG - Centre Équation | Tel: (+33 / 0) 4 56 52 04 42
2, avenue de Vignate      | Office nr B2G2
38610 GIÈRES - FRANCE     | http://www-verimag.imag.fr/~corbinea/
begin:vcard
fn:Pierre Corbineau
n:Corbineau;Pierre
org;quoted-printable:Universit=C3=A9 Joseph Fourier - Grenoble 1;Laboratoire VERIMAG - Polytech' Grenoble
adr;quoted-printable;quoted-printable:2, avenue de Vignate;;VERIMAG - Centre =C3=89QUATION ;GI=C3=88RES ;;38610;France
email;internet:Pierre.Corbineau AT imag.fr
title;quoted-printable:Ma=C3=AEtre de Conf=C3=A9rences
tel;work:+33 (0) 4 56 52 04 42
tel;fax:+33 (0) 4 56 52 03 44
x-mozilla-html:FALSE
url:http://www-verimag.imag.fr/~corbinea
version:2.1
end:vcard
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
