- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Why destructing does not work in this case?
- Date: Tue, 29 Nov 2011 18:36:53 +0200
- Envelope-from: porton AT yandex.ru
The following (correct) code proves under certain conditions equality of two
dependent records (of type Foo) with one data field and one condition:
Require Import Logic.ProofIrrelevance.
Parameter A : Set.
Parameter B : A -> Prop.
Structure Foo := mkFoo { a : A; b : B a }.
(*Axiom proof_irrelevance: forall (P:Prop), forall (p q:P), p=q.*)
Theorem thm (u v : Foo) : (a u = a v -> u = v).
proof.
consider x0 such that y0:(B x0) from u.
consider x1 such that y1:(B x1) from v.
assume e:(x0=x1).
claim (forall y:B x1, mkFoo x0 y0 = mkFoo x1 y). (* generalize *)
per cases on e.
suppose it is (refl_equal). (* dependent elim *)
let y':(B x0).
thus thesis by (proof_irrelevance _ y0 y'). (* automation sometimes needs
help *)
end cases.
end claim.
hence thesis.
end proof.
Qed.
I tried to generalize this code for the case of two data fields and one
condition. My theory does not verify however, at [suppose it is (my_eq_refl A
B).] it does not happen equalizing of variables matched by the same
meta-variables in my pattern. What is my error?
Parameter A : Set.
Parameter B : Set.
Parameter Cond : A -> B -> Prop.
Structure Foo := mkFoo { a : A; b : B; cond : Cond a b }.
Inductive my_eq (A B:Type) : A*B -> A*B -> Prop :=
my_eq_refl : forall (x:A) (y:B), (my_eq A B (x,y) (x,y)).
Theorem thm (u v : Foo) : (a u = a v -> b u = b v -> u = v).
proof.
consider x0, y0 such that cond0:(Cond x0 y0) from u.
consider x1, y1 such that cond1:(Cond x1 y1) from v.
assume e1:(x0=x1).
assume e2:(y0=y1).
have e0:( (x0,y0) = (x1,y1) ).
then e:( my_eq A B (x0,y0) (x1,y1) ).
claim (forall cond:Cond x1 y1, mkFoo x0 y0 cond0 = mkFoo x1 y1 cond). (*
generalize *)
per cases on e.
suppose it is (my_eq_refl A B).
let cond':(Cond x0 y0).
thus thesis by (proof_irrelevance _ cond0 cond'). (* automation sometimes
needs help *)
end cases.
end claim.
hence thesis.
end proof.
Qed.
Victor Porton - http://portonvictor.org
- [Coq-Club] Why destructing does not work in this case?, Victor Porton
