- To: "Edward Z. Yang" <ezyang AT mit.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Pattern matching against forall / arbitrary arity functions
- Date: Thu, 08 Dec 2011 18:16:57 -0500
Edward Z. Yang wrote:
I recently found myself writing the following tactic:
Ltac exbamf := match goal with
| [ H : _ -> exists _, _ |- exists _, _ ] => destruct H
| [ H : forall _, _ -> exists _, _ |- exists _, _ ] =>
edestruct H
| [ H : forall _ _, _ -> exists _, _ |- exists _, _ ] =>
edestruct H
| [ H : forall _ _ _, _ -> exists _, _ |- exists _, _ ] =>
edestruct H
end.
Is there a way to write this more cleanly?
It's easy enough to do with a recursive Ltac function, where you start the recursion by passing the type of [H]. Let me know if you'd like more detail.
P.S.: It's nicer to write [ex _] instead of [exists _, _]. Though in theory this catches more uses of the underlying type family [ex], to me the real benefit is brevity.
- [Coq-Club] Pattern matching against forall / arbitrary arity functions, Edward Z. Yang
- Re: [Coq-Club] Pattern matching against forall / arbitrary arity functions, Adam Chlipala
