- To: "Edward Z. Yang" <ezyang AT mit.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Pattern matching against forall / arbitrary arity functions
- Date: Thu, 08 Dec 2011 18:53:09 -0500
I noticed that this is harder than it looks, so here's my solution!
Ltac exbamf' T :=
match T with
| fun _ => ex _ => idtac
| fun x => forall y, @?f x y =>
let f' := eval simpl in (fun p => f (fst p) (snd p)) in
exbamf' f'
end.
Ltac exbamf := match goal with
| [ H : ?T |- ex _ ] => exbamf' (fun _ : unit => T); edestruct H
end.
Goal (exists x, x = x + 0) -> exists x, x = x + 1 - 1.
intros; exbamf.
Abort.
Goal (forall y, exists x, x = x + y) -> exists x, x = x + 1 - 1.
intros; exbamf.
Abort.
Goal (forall y z, exists x, x = x + y + z) -> exists x, x = x + 1 - 1.
intros; exbamf.
Abort.
Adam Chlipala wrote:
Edward Z. Yang wrote:
I recently found myself writing the following tactic:
| [ H : _ -> exists _, _ |- exists _, _ ] => destruct H
| [ H : forall _, _ -> exists _, _ |- exists _, _ ] => edestruct H
| [ H : forall _ _, _ -> exists _, _ |- exists _, _ ] => edestruct H
| [ H : forall _ _ _, _ -> exists _, _ |- exists _, _ ] => edestruct H
end.
Is there a way to write this more cleanly?
It's easy enough to do with a recursive Ltac function, where you start the recursion by passing the type of [H]. Let me know if you'd like more detail.
P.S.: It's nicer to write [ex _] instead of [exists _, _]. Though in theory this catches more uses of the underlying type family [ex], to me the real benefit is brevity.
- [Coq-Club] Pattern matching against forall / arbitrary arity functions, Edward Z. Yang
- Re: [Coq-Club] Pattern matching against forall / arbitrary arity functions,
Adam Chlipala
- Re: [Coq-Club] Pattern matching against forall / arbitrary arity functions, Adam Chlipala
Adam Chlipala
