coq-club - Re: [Coq-Club] Solving equalities over R, Rcompute fails
chronological Thread
  • From: Fr�d�ric Besson <frederic.besson AT inria.fr>
  • To: Ramon Snir <ramonsnir AT gmail.com>
  • Cc: coq-club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Solving equalities over R, Rcompute fails
  • Date: Sun, 1 Jan 2012 19:11:40 +0100
Using Coq 8.4, the linear real arithmetic tactic (lra) also does the job.
Require Import Reals.
Require Import Psatz.
Open Scope R_scope.
Goal 7 / 2 * 3 = 21 / 2.
Proof.
  lra.
Qed.
On 1 janv. 2012, at 16:36, Ramon Snir wrote:
> Hurrah!
> Works like a charm!
> On 01/01/2012 17:29, Laurent Théry wrote:
>> On 12/31/2011 05:27 PM, Ramon Snir wrote:
>>> Hello!
>>> I am trying to automate proving multiple equalities over R (would be a
>>> shame if I'd have to manually prove everything), but Rcompute seems to
>>> fail on many cases.
>>> This code:
>>> Proof.
>>> Rcompute.
>>> Qed.
>>> Generates:
>>> Toplevel input, characters 0-8:
>>> In nested Ltac calls to "Rcompute" and "apply IZR_eq" (expanded to
>>> "apply IZR_eq"), last call failed.
>>> Error: Impossible to unify "IZR ?6656 = IZR ?6657" with
>>> "IZR (1 + 2 * (1 + 2)) / IZR 2 * IZR (1 + 2) =
>>>  IZR (1 + 2 * (2 * (1 + 2 * 2))) / IZR 2".
>>> What other way is there to prove almost trivial R equalities?
>> You can use the field tactic that proves all equalities that are true
>> modulo associativity,
>> commutativity and distributivity
>> Require Import Field.
>> Open Scope R_scope.
>> Proof.
>> field.
>> Qed.
