- To: Coq-Club <coq-club AT inria.fr>
- Cc: Takashi MIYAMOTO <tmiya AT bu.iij4u.or.jp>
- Subject: Re: [Coq-Club] Defining the function using refine
- Date: Sat, 7 Jan 2012 20:39:39 +0900
Dear Pierre,
Thank you for your advice.
On 2012/01/07, at 20:29, Pierre Boutillier wrote:
> Le 7 janv. 12 à 12:14, Takashi MIYAMOTO a écrit :
> You use the dark magie of the return clause (my coq does not find ln
> definition so this is not tested and there must be typo):
In my first code, I forgot to add "Require Import List". The predicate "In"
is in the
List library.
I tried the removing the return clause, but the situation was the same.
> (the return clause should be in fact infered)
Takashi Miyamoto
http://www.imasy.or.jp/~miyamoto/
http://tmiya.blogspot.com/
- [Coq-Club] Solving equalities over R, Rcompute fails, Ramon Snir
- Re: [Coq-Club] Solving equalities over R, Rcompute fails,
Laurent Théry
Ramon Snir
Frédéric Besson
Ramon Snir
- Re: [Coq-Club] Solving equalities over R, Rcompute fails, Frédéric Besson
Ramon Snir
Frédéric Besson
Ramon Snir
- [Coq-Club] Defining the function using refine, Takashi MIYAMOTO
- Message not available
- Re: [Coq-Club] Defining the function using refine,
Pierre Boutillier
- Re: [Coq-Club] Defining the function using refine, Takashi MIYAMOTO
Pierre Boutillier
AUGER Cédric
Hugo Herbelin
Hugo Herbelin
Pierre Boutillier
Pierre Boutillier
Laurent Théry
