- To: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- Cc: Matthieu Sozeau <mattam AT mattam.org>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type classes and proof automation
- Date: Tue, 10 Jan 2012 19:46:36 +0000
Ok, I have updated the rest of my proofs, and your suggestion works beautifully. You sir are a genius :)
So to wrap up: given a class
Class LC (T : Type) :=
lc : T -> Prop.
I follow Matthieu's suggestion and define instances this way:
Inductive lc_SrcTerm : LC SrcTerm :=
| lc_S_Nil : lc S_Nil
| lc_S_Pre : forall n P, lc n -> lc P -> lc (S_Pre n P)
| lc_S_Par : forall P Q, lc P -> lc Q -> lc (S_Par P Q)
| lc_S_Res : forall L P, (forall x, x \notin L -> lc (P ^^ x)) -> lc (S_Res P)
| lc_S_Trans : forall L P Q, (forall x, x \notin L -> lc (P ^^ x)) -> lc Q -> lc (S_Trans P Q)
| lc_S_Co : forall n, lc n -> lc (S_Co n)
| lc_S_Rec : forall L P, (forall x, x \notin L -> lc (P ^^ x)) -> lc (S_Rec P)
| lc_S_PVar : forall n, lc n -> lc (S_PVar n).
Existing Instance lc_SrcTerm.
where we can use lc in the recursive hypothesis (directly); and given a
Class Permute T :=
permute : Permutation -> T -> T.
I follow Robbert's suggestion and define instances like
Instance permute_SrcTerm : Permute SrcTerm := fix permute_SrcTerm p t :=
let rec := @permute _ permute_SrcTerm in
match t with
| S_Nil => S_Nil
| S_Pre n P => S_Pre (permute p n) (rec p P)
| S_Par P Q => S_Par (rec p P) (rec p Q)
| S_Res P => S_Res (rec p P)
| S_Trans P Q => S_Trans (rec p P) (rec p Q)
| S_Co n => S_Co (permute p n)
| S_Rec P => S_Rec (rec p P)
| S_PVar n => S_PVar (permute p n)
end.
This means that all recursive occurrences are in terms of the type classes, rather than their instances, which greatly improves proof automation. Nice :)
Thanks!
Edsko
- [Coq-Club] Type classes and proof automation, Edsko de Vries
- Re: [Coq-Club] Type classes and proof automation,
Matthieu Sozeau
Edsko de Vries
Edsko de Vries
Matthieu Sozeau
- Re: [Coq-Club] Type classes and proof automation, Edsko de Vries
Robbert Krebbers
Edsko de Vries
Edsko de Vries
Matthieu Sozeau
Edsko de Vries
Edsko de Vries
Matthieu Sozeau
