- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type classes and proof automation
- Date: Fri, 6 Jan 2012 13:37:35 +0000
In this particular case, where [LC] is a definitional type class, you can directly write:Class LC T :=lc : T -> Prop .Inductive term := pair (t u : term) | atom.Inductive LC_term : LC term :=LC_term1 t u : lc t -> lc u -> lc (pair t u).This is because [LC term] unfolds to the arity [term -> Prop] andconstructors are typechecked in a context where [LC_term : LC term]so you have your recursive instance available.You get your induction principle for free:About LC_term_ind.(*LC_term_ind :∀ P : term → Prop,(∀ t u : term, lc t → P t → lc u → P u → P (pair t u))→ (∀ t : term, LC_term t → P t)*)You then just have to add: [Existing Instance LC_term] to register it,
Ah, that certainly makes it a lot cleaner, thanks! Is it possible to do something similar for recursive functions? Say,
Class Permute T :=
permute : Permutation -> T -> T.
and then use permute in recursive calls?
Edsko
- [Coq-Club] Type classes and proof automation, Edsko de Vries
- Re: [Coq-Club] Type classes and proof automation,
Matthieu Sozeau
- Re: [Coq-Club] Type classes and proof automation, Edsko de Vries
Edsko de Vries
Matthieu Sozeau
Robbert Krebbers
Edsko de Vries
Edsko de Vries
Matthieu Sozeau
Edsko de Vries
Matthieu Sozeau
